Ranger, Tach.
Old Dec 17, 2003 | 02:05 PM
zrtkicks's Avatar
zrtkicks
Ranger, Tach.
Hey evryone, my kid has a 99 Ranger Sport with the 2.5 dual coils and 2 plugs per cylinder, any one know how to put a tach. in it? we tried once and the tach only read 300 rpm's. Ive also posted on the 4 banger board hope some one can help, Thanks Warren
Old Dec 17, 2003 | 02:32 PM
MisterCMK's Avatar
MisterCMK
There should be a tach feed wire coming out of the ignition module, or computer. Also, try setting the tach to V8, maybe that will help since there are 2 plugs per cylinder.
Old Dec 17, 2003 | 02:36 PM
DainBramage's Avatar
DainBramage
Try posting this in the Ranger forum, you might get more help in the right section.
Good luck.
Old Dec 17, 2003 | 09:49 PM
zman764's Avatar
zman764
I have a 1999 3.0 XLT 4speed auto, and i have the non tach. gauge cluster, i was woundering if it is possible (and not overly insanely complicated) to replace it w/ the gauge cluster w/ a tach.
Also any one know much about adding after market cruise?
Old Dec 18, 2003 | 06:08 AM
zrtkicks's Avatar
zrtkicks
aftermarket tach.
Hey all how are you today? My boy has a 99 ranger sport 2.5 4 banger, and he wants a tach. in it, we have tried to install one but with dual coils and eight spark plugs we are not sure how or where the leads go, we tried it once and the tach only read 400 rpm at an idle and helpfull hints? thanks Warren
Old Dec 18, 2003 | 11:40 AM
stRanger706's Avatar
stRanger706
ha, i had a 97 ranger with no tach also and wanted to install one. i learned the hard way. the tach signal you need comes out of the powertrain control module. you dont need to take the pcm out, you just need to splice into a wire that is part of the harness that is plugged into the pcm. ok, first locate the pcm. its on the firewall, near the top/passenger side of the engine compartment with one bolt in the middle. its rectangle. unbolt the harness and unplug it. what you have to do is splice into a wire that is bundled in there with all the other wires, being held together with black tape. on my 97 the wire for the tach signal was brown with a white stripe. now if i were you i would call your dealer and make sure it is the same wire. if it is, just splice into this wire, connect your tach wire to it and tape it back up and plug the harness back into the pcm.
Old Dec 18, 2003 | 07:28 PM
Ken00's Avatar
Ken00
The tach wire is tn/yel and runs from the PCM to the instrument cluster.
You can swap in a cluster from a truck with the same engine, its wired for it.
Old Dec 18, 2003 | 07:31 PM
zman764's Avatar
zman764
i have looked at them and it appears as though the odometer/trip aren't in the same locatoin, do they slide over or how would that work?
Old Dec 19, 2003 | 04:26 AM
zrtkicks's Avatar
zrtkicks
stranger, ken thanks alot for the great info, we will give it a try this weekend, thanks again, Warren
Old Dec 19, 2003 | 03:27 PM
AlfredB1979's Avatar
AlfredB1979
You probably could get a speedo shop to turn the numbers over for you. Just for the sake of keeping needles in line and in one piece, that's how i would do it.
As for aftermarket cruise, JC Whitney's has kits....if you happened to find some junkyard trucks with the cruise still intact....well, you'd have to swap a lot of stuff for that.
Old Dec 19, 2003 | 07:22 PM
Ken00's Avatar
Ken00
I'm not familar with the non-tach clusters, both of my Rangers have tachs, but they are electronic so location wouldn't matter. Just make sure you get on from a similar year.
