Carburetor
Old Dec 17, 2003 | 11:51 AM
motorhomenut's Avatar
motorhomenut
Carburetor
Would you be kind enough to tell me the proper carburetor for my Ford
chassis motorhome w/ a 460 cid engine and an automatic transmission.
Thank you very much,
John Callahan
Old Dec 17, 2003 | 02:23 PM
walt80's Avatar
walt80
I have an Edelbrock 750 (1407) and it seems to be plenty on my 460.
Old Dec 17, 2003 | 03:21 PM
motorhomenut
caburetor identification
I got this info from the tag on the carburetor. As near as I can make out it reads:
Motorcraft
E3TE R2
213
Does that make any sense?
Thank you
Old Dec 18, 2003 | 08:13 AM
classic79's Avatar
classic79
any parts store should be able to get you a suitable replacement or a rebuild kit based on the numbers you pull off your carb, and the year of the chassis.
Old Dec 18, 2003 | 03:00 PM
motorhomenut
Electric choke problem
I need directions on how to set an electric choke. I've seen them somewhere in the forums but haven't been able to find them.
Thanks
Old Dec 19, 2003 | 12:12 AM
kermmydog's Avatar
kermmydog
Look on the air horn and you will find ALL the numbers, You didn't say what year your motorhome was. My guess is you have a Holley 4180, this carb is a very good carb, it runs a dual stage power valve, probably #612 jets, its one draw back is if it is a pre-92 it has NO power valve protection making it easy to blow power valves, CENTREX makes a power valve protection for $12.00 to your front door and it can be installed without taking carb apart. If it is a 4180 Holley and you decide to toss it out let me know.
Old Dec 19, 2003 | 12:28 AM
kermmydog's Avatar
kermmydog
Oh, a couple of other things, if it is the stock HOLLEY it is a 600CFM. If you are going to rebuild it you will need the motorcraft # which is your tag number. If you are going to change carbs and are wondering what CFMs to get, I can share with you when I did some mods to mine I had a clear vision as to where I was going in the long term I contacted HOLLEY techs. and layed out what I was tring to do and they told me to stay with the 600CFM. That is also an ave. Probably more info than you wanted.
Old Dec 19, 2003 | 05:09 PM
motorhomenut
Thanks for your response kermmydog. I have the Motorcraft number, it is E3TE R2. Ive got to try to see if I can get the numbers on the horn. The air cleaner is hard up against the under side of the dash - windshield, and its very hard to see up in under there ( I know I have to take the air cleaner out)
Thanks again
