2.8 sensor question
Old Dec 17, 2003 | 10:49 AM
Blownup5.0's Avatar
Blownup5.0
2.8 sensor question
I have a 1985 Ranger with the 2.8. There is a sensor mounted in the air cleaner. What is it called and what does it do?
Old Dec 17, 2003 | 09:31 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Blownup, it's an intake air temperature sensor. It controls the flap that feeds heated air to the air cleaner.
Old Dec 18, 2003 | 10:50 AM
Blownup5.0's Avatar
Blownup5.0
Thank's man.
Old Dec 19, 2003 | 12:40 AM
pat67shorty's Avatar
pat67shorty
No, that one doesn't control the hot air valve on the air cleaner snorkle. The IAT sensor tells the computer what temp the air is that the engine is ingesting. On 85's, the computer *may* use the data from that sensor to open/close that valve, since on a 85 they are vacuum solinoid controlled. On the 83/84, they used a bi-metal temp sensor hooked to manifold vacuum to control it.
