Front end not locking
Old Dec 16, 2003 | 09:24 PM
Ford6.9's Avatar
Ford6.9
Question Front end not locking
The truck is a 1985 F250 6.9 diesel 4X4. (manual locking hubs, Dana 50)
I took it in to have a U-joint replaced on the left front axle, it was getting pretty sloppy. Before I had that done the front end locked in and out just fine. Now we have a little snow on the ground, and I've got mini vans climbing hills around me. THAT's Embarrasing!
Anyway I'm taking it back into the shop tomorrow.
Question: Is it true that if one axle is not locking in, that it would cause neither to work?
I'm hoping nothing major here. But I noticed while in 4 high, the drive shaft to the front axle is turning, the rear wheels are spinning too because I'm stuck, waving to grandma as she drives her VW around me ! But the front axles are not turning.
Does this sound major, or simple?
Thanks
Ford6.9
Old Dec 17, 2003 | 08:28 PM
danaguy's Avatar
danaguy
did they change both u-joints in the front? mabey they havent put the hubs back together right?
Old Dec 17, 2003 | 09:54 PM
Ford6.9's Avatar
Ford6.9
Thanks for your reply,
They just replaced the left side. I found out today that the lock-out on the right side needs replaced. He showed me while it was apart that the coil spring had worn so much that part of it had broke off inside.
Then come to find out, you can't just buy the coil spring, you have to buy the whole lock-out assembly.
Anybody no where I can just get the coil spring?
Old Dec 18, 2003 | 06:27 AM
danaguy's Avatar
danaguy
id just buy new lockouts they are about 50- 70 bucks and they are much nicer than stock. they do away with the spring and go to a gear system.
Old Dec 18, 2003 | 04:51 PM
Txquadhunter24's Avatar
Txquadhunter24
I'd just buy New warn hubs. Plus they come covered for life. But if you can't swing the cost of new at this time. Just head to a wrecking yard. Ford, Dodge and Chevy hubs are all the same.
Old Dec 18, 2003 | 04:57 PM
Big Orn's Avatar
Big Orn
Re: Front end not locking
Yes. You have an open differential.
