steering control
Old Dec 16, 2003 | 03:54 PM
dandep's Avatar
dandep
steering control
I have a 2000 X with about 40 k on it. When I'm driving on the highway I feel like I don't have control of the steering. It's not so bad that it's dangerous but I feel I can't keep it in a straight line. If I replace that single shock connected to the suspension parts will remedy this issue.
Thanks in advance for any help
Old Dec 16, 2003 | 04:19 PM
shunshine X's Avatar
shunshine X
I have the same problem.
The truck doesn't feel stable (I know it is not a sports car) and it never felt it was alligned right. It is doing this since I bought it and the tires were almost new at the time.
the tire stores (tire kindom, tires plus and dealership) keep
blaming the tires (michelin LTX m/s) because they are almost worn out (by now. 46k on tires) But they also try to blame it on the tires when they were almost new...
Sorry I could not help you but hopefully i can get some info out of your problems
Old Dec 16, 2003 | 05:17 PM
emtabmm's Avatar
emtabmm
guy's, check your email
Old Dec 16, 2003 | 06:13 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
man that's not fare I don't get to see there stuff
I'll show ya mine if ya show me there's
Old Dec 16, 2003 | 07:06 PM
Forest's Avatar
Forest
Hey, me too!
I don't understand this wandering issue either. It is not uncontrollable, but it sure is vague "on center"--and the steering is pretty stiff to boot.
If Ford has a better idea, I sure would like to hear it...
Old Dec 16, 2003 | 07:10 PM
IB Tim's Avatar
IB Tim
Originally posted by Forest
Hey, me too!
Do you drive predominantly on pavement or concrete
Old Dec 16, 2003 | 09:05 PM
Forest's Avatar
Forest
Asphalt and concrete. Problem is there most of the time. Truck ruts make it worse (dog-tracking). No perceptible "bump-steer". Truck just requires constant attention to keep it going in a straight line.
Old Dec 17, 2003 | 09:52 AM
Bajarider's Avatar
Bajarider
Dandep:
I have an '04 4X4 with less than 2,000 miles, and it is not a good handler. That shock that you refer to is to dampen steering "shimmy" in a solid axel, if it occurs. It will do nothing for wander. Wedges between the leaf springs and axel can be used to increase caster and give a more stable on center feel, and better directional control, but will increase the chance of shimmy and tire wear.
I will be doing some suspension tuning to mine. I will probably replace the stock rear sway bar with a thicker bar (Helwig), replace the 265 tires with 285's, and use tunable Bilstien shocks to dial in the compression dampening. I use Bilsteins on the Baja car, they are easy to tune by changing the disks, but require that the gas (nitrogen, I think) be recharged each time you change the disks, or rebuild the shocks, but the effort is well worth it.
Old Dec 17, 2003 | 09:56 AM
Bajarider's Avatar
Bajarider
Originally posted by Bajarider
Dandep:
I have an '04 4X4 with less than 2,000 miles, and it is not a good handler, even considering it's size and weight. That shock that you refer to is to dampen steering "shimmy" in a solid axel, if it occurs. It will do nothing for wander. Wedges between the leaf springs and axel can be used to increase caster and give a more stable on center feel, and better directional control, but will increase the chance of shimmy and tire wear.
I will be doing some suspension tuning to mine. I will probably replace the stock rear sway bar with a thicker bar (Helwig), replace the 265 tires with 285's, and use tunable Bilstein shocks to dial in the compression dampening. I use Bilsteins on the Baja car, they are easy to tune by changing the disks, but require that the gas (nitrogen, I think) be recharged each time you change the disks, or rebuild the shocks, but the effort is well worth it. Ford should have done this, especially considering all the heat they took for the Explorer and Firestone tire fiasco.
Old Dec 30, 2003 | 04:22 PM
bluncrw's Avatar
bluncrw
So what was done to fix the problem?
