Offroad & 4x4
winch mount idea
Old Dec 16, 2003 | 02:21 PM
boss460's Avatar
boss460
winch mount idea
im about to mount my winch. should i mont it bumper level or should i mount it above the bumper and cut my grill. i want the winch to set as far back as i can get. if you look in my gallary under 78 you can see the winch. pic of home made winch bumper and winch mount would be nice
thanks for the help and idea
Old Dec 16, 2003 | 06:54 PM
gdavis2265's Avatar
gdavis2265
take a look at my galley, I made my bumper out of tube and plate- it might give you some ideas for yours
Old Dec 16, 2003 | 06:57 PM
gdavis2265's Avatar
gdavis2265
i looked at your winch, is that a PTO driven one? I have always wanted one (when I had my NP435 to run it)
Old Dec 16, 2003 | 07:53 PM
fishmanndotcom's Avatar
fishmanndotcom
Re: winch mount idea
if you are really gonna use it and want it to be as strong as possible you need to put all of the stress in line with the frame. putting it up in the grill is just asking for a bent bumper...although I think it would look pretty 'tricked out'
-jason-
Old Dec 17, 2003 | 03:32 AM
boss460's Avatar
boss460
no its not a PTO driven one realy its elec 3 gear reduction but it looks like it could be converted to PTO dont think i would like a PTO driven winch. cuz the one time i would need it would be the one time my truck wont start.
i didnt think about the stress factor but with the bumper i plan on building i dont think it wiuld be a big problem but im rethinking my plan now thanks dude. i like the looks of the high mount too and want it set back cuz i dont want it sticking out 2 feet.
Old Dec 17, 2003 | 08:33 AM
fishmanndotcom
no prob man....another thing i was thinking about this morning is if you put in front of your grill you might have cooling issues with it being in front of your radiator!
just looking out for ya
-jason-
Old Dec 17, 2003 | 08:36 AM
gdavis2265's Avatar
gdavis2265
That's what I tried to do with mine, I used a flat 3/8" plate on the bottom of the winch, that connects to two vertical plates that tie directly into the mainframe. The winch line-pull is on the bottom, close to the plate- so the winch pulls in-tension with the frame rails. Make sure you use some good 5/8" grade 8 Bolts and nuts. I also welded the nut to the bolt on the ends to prevent sombody stealing the whole set-up.
Old Dec 17, 2003 | 08:47 AM
fishmanndotcom
pics???
Old Dec 17, 2003 | 08:50 AM
gdavis2265's Avatar
gdavis2265
Fishmann,
Click on my galley under the pic of my truck- there are a couple of pics of my front bumper and an AutoCAD solid model I used to make the bumper.
Old Dec 17, 2003 | 10:08 AM
rebocardo's Avatar
rebocardo
That lime green monster is awesome! That is exactly the truck I was looking to buy, but, could not find so I settled for a F-100 instead. Just awesome!
Old Dec 17, 2003 | 10:12 AM
gdavis2265's Avatar
gdavis2265
Thanks so much. I love the truck and have spent a year and half of my time and money into it, so I really appreciate it.
Old Dec 17, 2003 | 10:29 AM
rebocardo's Avatar
rebocardo
Your winch looks too big to mount between the frame rails, so I would mount it above to the frame rail with sideplates (outside).
Old Dec 17, 2003 | 12:52 PM
boss460's Avatar
boss460
it will fit in the frame no problem but give more detail on the side plate idea.
fishmanndotcom i dont think cooling would be that big of adeal im putting a bigger rad in it cuz bigger is always better right
Old Dec 17, 2003 | 01:45 PM
fishmanndotcom
ahhhhh, ok. kool man....i just thought i might bring it up just in case
-jason-
Old Dec 17, 2003 | 09:39 PM
muscletruck7379's Avatar
muscletruck7379
boss460- your winch looks like the one im planning on plopping onto my bronco, but mine is pto driven, what make/model is yours?
