No Codes What Is Wrong?
Old Dec 16, 2003 | 01:20 PM
ARNO60's Avatar
ARNO60
HI, I HAVE A 1992 F-150 5.0 -4X4. NO CODES ARE COMING UP,THE TRUCKRUNS GOOD AT A HIGH RPM,BUT WHEN JUST PUTTING ALONG AT A LOW RPM 1500 OR LOWER THE TRUCK SEEMS TO HAVE A HESITATION IN IT AND NOT VERY MUCH POWER.UNTIL I KICK DOWN TO A LOWER GEAR AND GET THE RPM'S UP THEN IT RUNS FINE. JUST GAVE IT A COMPLETE TUNE-UP,
NEW FUEL FILTER.GARAGE TOLD ME TO TRY RUNNING HIGH TEST
GAS , DID NOT HELP. I HAVE BEEN TOLD EVERYTHING FROM THROTTLE SENSOR TO TORCH CON. SHUDDER IS THE PROBLEM.
BUT WITHOUT ANY CODES TO STEER ME IN THE RIGHT PLACE I HAVE NO CLUE WHERE TO START.DOES ANYONE HAVE ANY IDEAS
THANK YOU FOR YOUR HELP!!!!!!!!
Old Dec 16, 2003 | 08:16 PM
EPNCSU2006's Avatar
EPNCSU2006
Have you done a tune up recently? If not, that would be a good place to start. Maybe also try some fuel injector cleaner.
Old Jan 20, 2004 | 03:24 PM
bob arrington's Avatar
bob arrington
no codes usually means a bad ground somewhere, if you have a bad ground your controll box wont send any signals or recieve then . the other 'much worse ' option is that your brain is dead , another test might be a back pressure test at the cat, but you would still show codes . are you using a hand held tester or are you reading the check engine light? the hand held costs about $40.00 bucks and is a good way to verify things. run a 10 guage wire from the negative post on your battery to the frame, then to the firewall . any clean bolt or screw will do . good luck ,bob
Old Jan 20, 2004 | 05:52 PM
EPNCSU2006's Avatar
EPNCSU2006
Usually a clogged cat will cause problems at anything above an idle, which is opposite of his problems. I agree about checking the computer wiring, that's usually the problem. Check continuity between SIGRTN and ground as well. Somehow I don't remember making that post above...
Old Jan 21, 2004 | 12:27 AM
LxMan1's Avatar
LxMan1
Does a 92 have a mass-airflow sensor? If so, it may be dirty.
Jimmy
motogp310
Modular V10 (6.8l)
Oct 12, 2011 07:06 AM
TKulak
Jan 22, 2010 06:33 PM
DCRB
Aerostar
Dec 27, 2007 08:52 PM
Brian1477
3.8 & 4.2L V6
Aug 22, 2006 04:09 PM
quads
Oct 9, 2000 01:59 PM
