twin plug ignition
Old Dec 16, 2003 | 01:06 PM
petrixx's Avatar
petrixx
twin plug ignition
Hi guys!
I need some help with my ranger 91´ 2.3 lt. twin plug ignition.
My truck was running so good but like a month ago, I took out the spark plugs to clean them up, then i put them back and I tryed to turn it on, but it won´t start, the engines rotates but won´t start.
I got spark on the right coil(passenger side), But not in the left coil
the gas pump is working,the inertia switch is resetted, and i also check the DIS module, the timing marks on crankshaft and camshaft are lined up,I did´nt check the crankshaft timing sensor but I think is working cause I got spark on right coil.
Okey here is a cuestion for you guys!
If got spark and gas injected, when the engine cranks, why it does´nt make any stalls or backfires?
I will really appreciate your help to find out what is wrong with my truck.
thanks.
Petrixx
Old Dec 16, 2003 | 01:13 PM
Mike W's Avatar
Mike W
Welcome to FTE! I suppose this is a dumb question but are the plug wires in the right order?
Old Dec 16, 2003 | 04:18 PM
el conquistador's Avatar
el conquistador
did you have to unplug the coilpack in order to get the first plug out. I know I did. see if it's plugged in.
Old Dec 16, 2003 | 06:21 PM
Ken00's Avatar
Ken00
Have you tried pulling the codes?
Old Dec 16, 2003 | 06:47 PM
rellik74's Avatar
rellik74
only 1 coil fires at start up the other coil kicks in as rpm go up, dont remember the # of rpm when othe coil kicks in.
