power door lock driver side
Old Dec 16, 2003 | 12:26 PM
randj's Avatar
randj
when i use my keyless entry, i usually have to hit it a couple of times for the driver side lock to unlock. it sort of eases up a little each time i hit the button, usually 2-3 times before i can get in. anyone else have this problem before i start ripping the door apart?
thanks
Old Dec 16, 2003 | 05:52 PM
emtabmm's Avatar
emtabmm
failing door lock actuator....
Old Dec 16, 2003 | 06:38 PM
2ndoldogy's Avatar
2ndoldogy
I had the drivers door lock assembly failure on my 1998. Was lucky to even get the door open. Had to replace the entire lock assembly, about $30. if I remember right. The replacement was a redesigned assembly. Parts guy indicated he saw many of them go out the door and to the shop.
ray
'03 Explorer
'90 F350 Extended cab dually
1953 Ford Golden Jubilee Farm tractor
1948 Ford 8N farm tractor
1962 Ford 4000D with 723 backhoe and 703 loader
1955 Ford 850 Farm tractor
94 Monaco Dynasty motorhome with Cummins C8.3 with upgrades
