I have got this loud squeeking noise that I think is coming from one of the belts. It doesnt do it at idle but between 10-45 mph it is loud and annoying. When im at highway speed you can faintly hear it, high pitch. It dissappears and reappears....any suggestions as to what it is and a remedy...thanks....
Originally posted by bajarunner68 I have got this loud squeeking noise that I think is coming from one of the belts. It doesnt do it at idle but between 10-45 mph it is loud and annoying. When im at highway speed you can faintly hear it, high pitch. It dissappears and reappears....any suggestions as to what it is and a remedy...thanks....
HEy this is a dumb question maybe its the turbo noise???
thanks to all esp emtabmm, got my truck back this morning..the noise turned out to be the carrier bearing which they repaced and i'm down the road....the mech's hadn't seen the tech bulletin that emtabmm gave to me, and they said that it helped....thanks again to all....
Make sure to check your read differential. When my center bearing went, so did the pinion seal. Look for greasy dirt around the pionon flange and on the underside of the diff.
