clutch fan??
First remove the belt. I dont remember if I removed the fan shroud before or after removing the fan. The shroud only has two bolts so no big deal. Then you'll have to remove the fan from the clutch (4 bolts I think) and pull the fan/shroud out of the engine compartment. Then another 4 bolts hold the clutch to the engine. There is a pulley between the water pump and the cluch, so make sure no to drop/loose it. Installation is the reverse. It's actually very simple. Make sure to put the belt back correctly.
You'll need a wrench for the belt tensioner to remove the belt (5/8 I think). And the fan and clutch both use the same wrench, 7/16 I think.
If you just examine the whole setup you'll see how it all goes together.
