1978 - 1996 Big Bronco
idle problem
Old Dec 15, 2003 | 10:06 PM
iftbronco93's Avatar
iftbronco93
idle problem
My 93 bronco has a idle problem. I already changed the o2 sensor and that did not fix it. It has a new fuel pump, plugs, wires,cap and rotor. It is hard to start, you have to push the pedal all the way to the floor to get it started and after you do it idles erratically. Once it is warmed up it seems to run okay. Does anyone have any ideas?
Old Dec 15, 2003 | 10:51 PM
broncobillybob's Avatar
broncobillybob
this probably won't fix it, but try disconnecting the battery for about 10 minutes or so to reset the computer. my $ 0.02 -wb
Old Dec 16, 2003 | 11:21 AM
sactrack's Avatar
sactrack
can you describe "idle problem" in a little more detail? (i.e: low idle? missing at idle speed? running rough? etc...)
Old Dec 16, 2003 | 01:10 PM
AMDAP's Avatar
AMDAP
That is the same thing that I am going through. I changed all that stuff and then the FPR and the fuel filter. After all that it turns out that my cats are plugged. I was gonna replace them with the stock stuff but it is over a grand to do so. My Bronco has been at the shop for two months now. We don't have a exhaust shop here. My mechanic can't seem to find the Bassani stuff for me either. That is what I want, he just can't find it. If I order it myself, it is going to cost $250.00 for shipping...OUCH! Our problems do sound identical though. Do you have to keep on the gas until it is warmed up to keep it from stalling? Worse Mileage? Does it almost seem like the timing is off?
Old Dec 16, 2003 | 04:04 PM
AYoungblood's Avatar
AYoungblood
When you push the pedal to the floor, Ford has a neat little "gizmo": The more you push the pedal, the less gas it will squirt into the cylinder, until the engine starts and then it flips, more it is pushed, of course the more gas it will give it.
Hope that helps,
Adam
Old Dec 17, 2003 | 04:53 AM
iftbronco93
Response from members on idle problem
My idle is low and it does not miss. It does run rich. You can really smell it. I do not think my cat is plugged. I am going to try to read the codes again and see what comes up. Thanks for the help.
Old Dec 17, 2003 | 05:41 AM
RTM's Avatar
RTM
I would measure the injectors. When I measured mine they where all around 15.2 to 15.6 ohms. I would als look at the pressure regulator. it may be bad. Pull the vacuum line from the regulator and if there is signs of fuel its bad.
Those are a couple of simple things to check. I myself Ihave been chasing an idle searching problem. Which mostly happens when the truck is cold but it will happen after driving for a while. The truck will even stall once in a while and only when I am sitting still in gear will it stall. When the truck is in park it will idle all day long.
So I hope yours is easier to fix than mine. I have replaced every sensor on my truck with no luck.
My Nightmare
Jun 30, 2016 12:47 PM
tabijan
Feb 8, 2016 09:49 PM
evansz95
Apr 16, 2014 11:29 PM
DaddyMouse
Aerostar
24
Nov 18, 2005 09:17 PM
terrynnc
Aerostar
Mar 11, 2001 07:54 AM
