Sponsored by: Auxito
Hard Shifting
Old Dec 15, 2003 | 05:58 PM
11spurs's Avatar
11spurs
Hard Shifting
Has anyone had issues with thier manual tranny being hard to shift. I have a 99 Ford F-150, 4.2 manual tranny. When I am in nuetral and want to shift to any gear it is like hitting a wall. There is no noise but it will not slip into gear. I have to shift into 4th and then slip into first. I just had the trans fluid replaced and it did not help at all. It has no problem going into gear once I am driving. Is this common, or does anyone have any ideas as to what the problem may be.
Old Dec 16, 2003 | 12:18 AM
Racerguy's Avatar
Racerguy
It sounds like you have a clutch problem. The clutch probably isnt fully releasing. The most common thing I've seen is a leaking slave cylinder. It leaks fluid out and then air gets in causing the problem. Check the fluid level and see if it is down at all.
