Construction question
Old Dec 15, 2003 | 03:36 PM
Shepard's Avatar
Shepard
Since another post seemed to generate a lot of knowledgeable answers, I'll ask one I have wondered about for a while.
Around here, Oregon, you see lots of people building homes in the rainy season. Often the sub floor is down and exposed to weeks of rain as the framing is done. Then later sheathing is often exposed to the weather for weeks and weeks before it is covered with wrap and siding.
I have also seen roof sheathing get rained on and then covered the next day with tar paper and shingles.
Isn't this bad for the plywood etc., especially if it is not completely dried out before covering? Or is the material made to withstand this?
Old Dec 15, 2003 | 03:52 PM
fisher_of_man's Avatar
fisher_of_man
yeah...I think your right...I've seen the same thing. If the wood is still wet and covered that way, it CAN'T be good. But in most cases it comes down to the almight dollar. the construction company is trying to put up as many as they can as fast as they can and aren't going to go thru any extra steps. I don't think most of them care as long as they pass inspection and get their money.
Old Dec 15, 2003 | 04:07 PM
sinjin's Avatar
sinjin
It aint good but it will dry out over time from the warm dry air inside the finished home.
Old Dec 15, 2003 | 04:24 PM
Big Orn's Avatar
Big Orn
True and decking comes with external glue, so if it does get wet it will not affect the integrity of the whole sheet. I have seen them "swell" and then go back to normal size -after- the roofing is installed. Remember, the decking is exposed underneath where air can get to it. It's those pieces that get trapped that mold and deteriorate fast.
Old Dec 15, 2003 | 05:27 PM
wildjon300ci's Avatar
wildjon300ci
Beat me to it, one thing is that the subfloor usually is about the last thing to get covered on a construction project, usually long afgter the house has been dried in. Here's a little test for you, grab a piece of OSB and throw a little bit of water on it, watch what happens to the water. Then, on a warm day feel the OSB on it's slick side. The wax/glue leaves a grimy feeling on your hands.
Old Dec 15, 2003 | 06:48 PM
jskufan's Avatar
jskufan
In my opinion, the water doesn't do plywood or OSB any good. Ideally, the roof decking should be covered before it gets wet. The same for the OSB siding and especially any plywood floor decking. None of that material is rated for exterior exposure. Like someone else said, when it gets wet, it swells and I don't see how that doesn't compromise the strength of the board because as it "grows", somethings gotta give. What's giving is the glue / wood bond. None of these products have the characteristics of "real" wood, they're only used because of cost and convenience. Anyway, just my 2 cents!!
daddio360
13
Jul 16, 2006 07:54 AM
cigarxtc
Aug 31, 2005 11:45 PM
omni
16
Jul 8, 2005 01:11 AM
websthes
Dec 14, 2004 05:07 PM
IB Tim
Nov 28, 2003 07:01 AM
