throttle position sensor problems???
Old Dec 15, 2003 | 03:31 PM
JJFL99PSD's Avatar
JJFL99PSD
I have a 99 f25 psd with 140k miles. It runs great on the highway, but on occasion I will put the pedal to the floor and get no response. This happens around town at very low speeds. I am wondering if this is the throttle position sensor??? I have also read about "codes"... Could someone please explain in english a little about codes, and there opinion on the t.p.s. situation
thanks in advance for the help...this is a great forum...I have learned much in the past few days.
Old Jun 6, 2008 | 07:21 PM
Bambu's Avatar
Bambu
JJ,
I have a '00 F250 PSD that had the same issues you are describing. Not only that, I was experiencing rpm surges at low speeds and at high speeds. One day I had a bad throttle hesitation in an intersection then the engine sputtered and the SES (service engine soon) light came on. The truck made it home but the light remained on for the next few days. I had a buddy, who has basically the same truck, hook up his OBD (on-board diagnostic) and the code it read from the truck's computer was the tps. I ordered the tps from dieselsite.com, replaced the old one, and am back in business. The OBD's read the trouble codes that the on-board computer throws when the light comes on. There are several different OBD's but not all work for our trucks. A lot of guys use OBD-II. My guess is you need to replace your tps....good luck!
Old Jun 6, 2008 | 07:25 PM
Bambu's Avatar
Bambu
Auto-enginuity OBD is what I meant....cheers.
