Wastegate ?
Old Dec 15, 2003 | 01:13 PM
SBFD8's Avatar
SBFD8
Talking Wastegate ?
Stupid Question but What does the Wastegate do? What's it's function? If it is OK to disconnect the red vac line then will it hurt anything? Thanks Al
Old Dec 15, 2003 | 04:48 PM
bigdieseldav's Avatar
bigdieseldav
i hope someone can chime in later and give you a more technical answer but to the best of my understanding it is a feature that when boost exceeds ford engineering specifications 20-25 psi ( not certain) a gate in the exhaust turbine housing is engaged routing exhaust out of or around the exhaust turbine?? This in turn regulates boost pressures off of the compression turbine....I'm sure you will get a better answer, but I thought i would share my understanding or maybe mis=understanding... and no i don't think it will compromise anything, atleast that is what i have been told by the good people on this site.... Good Luck
Old Dec 16, 2003 | 11:26 AM
SBFD8's Avatar
SBFD8
