Some of you by now probably have received the update but I thought I'd post it anyhow.
Ford sent me new specs stating that lug nut torque is now 150-165 Lb. ft.
My old specs said 148 Lb. ft.
They also stated to put a drop of motor oil between the nut and washer and to NOT put any oil on the threads on the studs or nut. (which is a common fact anyway...)
>150-165 Lb. ft.
>Just an FYI.
Thanks for the post Monsta. I got mine in the mail last week. Just be careful not to Cross dress......did I say that??? I MEANT be careful not to CROSS THREAD your lug nuts....I just had to do it Monsta. I promise it will never happen again
>>Those are the specs that were given for my truck('02) both
>>in the manual and on the frame.
>Mine too.
Here's what I received and had.
I received a label to stick in my owners manual that lists the unchanged torque of 150-165 lbs.-ft.,the clean thread info, the drop of oil in between the nut and washer info and the retorque info.
I also received a new vinyl tire change instruction sheet.
The most significant difference is that the new sheet tells you to torque the wheel nuts to the 150-165ft.lb spec ASAP.
Whereas the old sheet instructed you to have them torqued ASAP to the spec listed in the Owner Guide.
On the vinyl instruction sheet,there is also a new WARNING about hanging the spare or flat tire and rim properly to avoid failure of cable and loss of spare tire.
Just an example of Ford CTA against potential lawsuits,I guess.
I recieved my notification last week also but wonder how you get accurate tensioning of the studs with dry threads. I was always taught to lube all threads. Even spit was better than nothing in a field condition.
>Actually lubing threads will throw off the torque readings.
>You can apply too much torque with lubed threads.
I guess I was just surprised to see FORD recommend no oil on threads. Would applying oil to a cylinder head bolt cause it to be overtightened or are wheel studs the exception?
I have been puting Never Seize on my wheel studs for the past 45 years and come to think of it I did lose a wheel once on a 1964 Galaxy 500.
Never too old to learn!
