leaking drain plug
Old Dec 15, 2003 | 10:54 AM
bluemoose89's Avatar
bluemoose89
leaking drain plug
i have a 99 psd 350 and my drain plug on the oil pan has a small drip leak. do i need to buy the new copper washer to stop the leak? or is the something else i can do?
Old Dec 15, 2003 | 11:07 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Yes.
Old Dec 16, 2003 | 11:58 AM
bluemoose89
thanks that sounds good
Old Dec 16, 2003 | 05:29 PM
reddhawk's Avatar
reddhawk
Those solid copper oil drain plug rings can be used again and again!. Its copper which can be anealed (heated to a cherry red then rapidly dunked into cold water) numerous times to soften and reuse. Aircraft engine sparklugs have the same type of copper seals. They are reused over and over.
I aneal mine while the oil finishes draining. Check it out.
Also, drain that oil filter canister before removing to prevent messy garage or driveway stains. Punch a hole in the bottom and let it empty first. Merry Christmas!
Old Dec 16, 2003 | 05:49 PM
so2315's Avatar
so2315
How do you heat up your washer? All I have is a propane torch. Does it work? Mine has the drips too at 40k miles.
Old Dec 16, 2003 | 06:17 PM
reddhawk's Avatar
reddhawk
I use my gas stovetop. Butane or propane would certainly work, too. Find a place in the flame that is the hottest. Use some old pliers or needlenose. Hold the ring in the flame until most of it changes to glowing red or orang. Dunk it in cool water until you can pick it up and rotate the ring so the pliers grip the opposite side, reheat and dunk again. That copper washer will "work harden" after several tightenings around that drain but this procedure will soften it like new. Eventually though, the copper will probably spread out enough to require replacement. I keep a spare that is ready to use, but its still in the wrapper after dozens of oil changes and aneallings of the copper washer.
Old Dec 16, 2003 | 08:24 PM
International Tech's Avatar
International Tech
not starting anything here but why wouldnt you just buy the part? I mean it cost less than .50 cents?? Just curious.
Old Dec 16, 2003 | 08:45 PM
Jlower's Avatar
Jlower
Buy a Fumoto Drain Valve and ditch the plug.
Old Dec 16, 2003 | 09:09 PM
reddhawk's Avatar
reddhawk
Drain valves and washers
Good suggestion too, but hardened copper washers can be made soft again FYI. I installed a Fumoto on my PSD couple oil changes ago. In fact I just finished ordering one for my wifes '03 Escape, 3.0 V6. I use a screw type hose clamp to secure the valve toggle for better security instead of their wire clamp.
'01 7.3 PSD, Lariat SC, 4X4
'03 Escape Limited, 3.0, 24 valve V6
Old Dec 16, 2003 | 09:20 PM
so2315's Avatar
so2315
I'm kinda liking this drain valve. Where is the cheapest place to get these? Does Wally-World have them?
Old Dec 16, 2003 | 09:23 PM
Jlower's Avatar
Jlower
Click Here ------->Fumoto
I havn't seen them anywhere else but from the companies website. Maybe some of the other guys might know.
Old Dec 17, 2003 | 07:03 AM
HeatStroked's Avatar
HeatStroked
I went to Checker and bought new copper washers.
I was considering the fumoto but not thrilled about having a critical component sticking out below the pan.
Plus, it provides easy access for devious individuals to disable your PSD if they should decide to roll under your truck and open it up, no tools needed.
Old Dec 17, 2003 | 09:58 AM
02PSD4ME's Avatar
02PSD4ME
DITTO
Old Dec 30, 2003 | 06:09 PM
BenRosey's Avatar
BenRosey
I would like to add on to the original question. I too have a 99 350 PSD. My oil drain plug leaks too.
The truck is new to me within a few months. On the first oil change I did (this last one), I used a new copper oil drain plug seal. Hooray.
It still drips oil, though. My question is whether or not the synthetic (plastic/nylon) seals are better than the copper ones. On all of my previous cars I have used the synthetic seals since they were available. I noticed that the outer diameter of the copper seal is just as large as the head on the bolt. The synthetic seals I have previously encountered are always a bit larger.
I've never been in the practice of gorilla'ing my drain plug tight. I am afraid that is what the previous owner did on an occasion or two and possibly stripped the hole. If so, are oversized drain plugs a good idea?
I'm thinking this through since I don't drive very frequently and I'm due for an oil change now.
I checked, and replacing the oil pan requires lifting the engine. I'm not in the mood for that. Although I may be one day if the drip keeps dripping. Drip, drip, grrrr...
Thanks in advance for your responses.
Old Dec 30, 2003 | 06:13 PM
HeatStroked
I ditched the copper washers and went with the synthetic, plastic style instead.
No leaks.
