Steering question
Old Dec 15, 2003 | 10:50 AM
steve6.0's Avatar
steve6.0
Steering question
When steering my 4x4 dually crew cab on tight parking lots (complete lock either side) I notice the front wheels are hoping like it does in four-wheel drive. I understand that being such a long vehicle at tight turning radius it does push the front end quite a bit but are the hubs suppose to be fully released when set in auto?
Is this a common behavior or not?
( hehee…61 feet curb to curb feels like turning an aircraft carrier!)
Thanks for any comments!
Steve6.0
Old Dec 15, 2003 | 12:23 PM
emtabmm's Avatar
emtabmm
Sounds like they are staying locked, have it checked.....
Old Dec 15, 2003 | 07:17 PM
steve6.0's Avatar
steve6.0
Thanks Mr. Service Advisor, I tought the same too, soon or later after the Holydays I will have it checked.
Old Dec 15, 2003 | 07:33 PM
cdtruckn's Avatar
cdtruckn
I think there is a TSB on the auto hubs.
Old Dec 15, 2003 | 07:39 PM
steve6.0's Avatar
steve6.0
Sorry, but what does it means "TSB" ?
Old Dec 15, 2003 | 07:43 PM
cdtruckn's Avatar
cdtruckn
0526 1999-2003 SUPER DUTY F SERIES, 2000-2003 EXCURSION FRONT LOCKING HUBS - SERVICE TIP
THIS TSB PROVIDES INFORMATION ON THE 4X4 SYSTEM, PARTICULARLY THE FRONT LOCKING HUBS. SEE TSB 03-04-01 ON OASIS AND FMCDEALER.COM FOR DETAILS.
technical service bulletin
Old Dec 15, 2003 | 07:54 PM
steve6.0's Avatar
steve6.0
Thanks I will look into right now.
Old Dec 16, 2003 | 07:09 AM
mn 6.0's Avatar
mn 6.0
Shouldn't matter if your hubs are locked or not, unless your transfer case is locked as well. All you have to do is jack up one wheel & it should spin free, the U joint should not be turning. Or turn the all the way to one side , drive slowly & have someone look at it. (don't run them over) Ford was having problems with the seals leaking for the auto hubs, I think that's why they went to auto or lock. That way if a seal does leak, you can still lock in the hubs & still have 4WD.
Old Dec 16, 2003 | 11:29 AM
steve6.0's Avatar
steve6.0
That's a very logical way to troubleshoot this issue, very good as soon as someone comes back around here I will try the parking lot method (without running over anyone, imagine what a nice Worker's Comp case that would be!).
Thank you
Old Dec 16, 2003 | 11:37 AM
steve6.0's Avatar
steve6.0
I try fmcdealer.com but that's a secure Webb site for Ford dealers, and the other one "oasis" (oasis.com) it's a high tech site.
Sorry I'm new to this forum and you need to be a little more specific with me. Thank you for being supporting.
Old Dec 16, 2003 | 11:56 AM
mn 6.0's Avatar
mn 6.0
Hey! it was meant to be a joke! You put in a comp claim & they will probably hunt me down & soo me!!! another thing to check would the alignment. This might be a reach but if you have a Detroit locker type rear diff. & that is staying locked for some reason, it might do what you are describing. Good luck & don't run yourself over!
Old Dec 16, 2003 | 12:03 PM
steve6.0's Avatar
steve6.0
Thank you, Keep up that good sense of humor!
Old Dec 16, 2003 | 07:02 PM
cdtruckn's Avatar
cdtruckn
This was meant for u to print if you want and take it with you to the dealer. sorry for the confusion
