no heat
Old Dec 14, 2003 | 11:38 PM
motorheadmach1's Avatar
motorheadmach1
no heat
im tired of not havign heat and im finally gonna do something about it. i need to put in a new thermastat but befor i buy one id like some input at what temp these trucks rin best at. its an 86 f150 4x4 with a 302 efi motor. i know it runs nice for me that way it is now, dead cold all the time. thats bad for winter tho. 195* is stock i think?
Old Dec 15, 2003 | 12:05 AM
howler's Avatar
howler
I run a 195' in my 83' F250, but have you checked if your heater core is flowing? or if it is plugged?
Old Dec 15, 2003 | 01:07 AM
Silver Bronco's Avatar
Silver Bronco
Those efi engines love heat i have a 195 in mine and it works great. don't go any lower i did to breakin my new engine in and the lower the thermostat the worst the gas mileage.
Old Dec 15, 2003 | 10:02 AM
nuts4hotwheels's Avatar
nuts4hotwheels
I use a 195 in my '86. As for the heat I would check the heater core and hoses to make sure that it is getting a good flow through it. Does any heat come out at all or is it just cold air?
Old Dec 15, 2003 | 05:43 PM
motorheadmach1
heat comes out bu its just warm. i know it has a 165* thermostat, put it in there in the summer when i did the waterpump and timing case. the engine never gets hot the air temp to engine temp ratio is abotu right. ill get one of those 195* t-stats this weekend.
Old Dec 15, 2003 | 06:00 PM
travisd's Avatar
travisd
195 is good, but make sure and spend the extra money on a fail safe thermostat. They seem to be one of the worst parts for being new and defective. I did exactly what you are doing to an 88 Daytona and the thermostat stuck closed on the first run after replacement and by the time I shut it down, both the radiator and heater core started leaking, major pain in the ****.
Old Dec 15, 2003 | 06:01 PM
love2fixit's Avatar
love2fixit
a thermostat can go bad and not close even new. I would replace it too.
