more carb problems
you may also be able to fabricate some kind of heat riser to air filter tube to get some warm air into the carb....
as for the carb itself, if the jetting is in the ball park, and the power valve is the right one for it, it's probably gonna need one of the above mentioned items..........( heat riser, ignition or different thermostat).
this is assuming ofcourse it runs fine when warmed up well and or in warmer time of year.
I usually just pull the plate out and only use the high idle part of choke. You can then pull it out to your hearts content and it only revs higher, instead of cutting the air off.
You can also adjust the amount of high idle also. I crank the screw up a bit to get it to hold throttle open more with less choke pulled.
Larry
PS: If you need some assistance in getting it apart, I'll send you a picture of mine. The newer carbs you just pull the blade out(with visegrips) and then remove rod and linkage. The older carbs you need to remove the two small screws and then slide plate out of rod.
My 750 has had the choke completely milled off of it
I had no problems getting my 390 startd on any cold day, just as long as the battery was good.
Fired right up, gave it a bit of throttle for a few mins (kept it around 1200 rpm) and she was good to go
I agree that the carb is overchoked, but depending on where you live removing it might be too much. I have for years cut the plate at an angle from top edge to near the center of the plate against the rear choke tower wall. That allows some choke action and allows more choke movement for fast idle without flooding.
I don't know if the description is good?
Basically you cut a fair sized triangle ouy of each upper corner!!
