What makes a Highboy?
Old May 16, 2004 | 05:51 PM
Craigwell's Avatar
Craigwell
yeah, my 76 HB is open knuckle, disc brakes up front.
I was under the impression also that it's a 1 ton frame.. beyond it being a ladder frame that doesnt flare out behind the cab like the 1/2 ton and post 77.5 f250's..
i do know that last year i replaced a cross member on my frame with one from an 85 F350 2WD .....
my truck is currently stripped down to the frame now. I am very impressed with how solid and thick it is, and am completely confident that it will have a half-life of about 25,000 years... heheh
Old May 16, 2004 | 06:42 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check the FAQ sticky at the top of the forum re highboy, always look there first guys.
Old May 17, 2004 | 04:48 AM
highboy1975's Avatar
highboy1975
i like to think of the frame rails on my hi-boy as similar to c-channels. the frame under these trucks is beafy. also, something that not many people mention is that the highboy with the np435/np205 combo is the transmission that is used in the 2wd version of the f250. just thought that could be added since i haven't seen it on here yet. when i get my hb done, im gonna drive it through the front door of the restaurant i work at and out the other side
Old Feb 24, 2005 | 10:14 PM
76highboy4x4
Guest
Posts: n/a
Highboy
Check the VIN. If it starts with F26 then It came stock from the factory as a Highboy. If it starts with F25 then It came stock from the factory as a regular old truck.
Old Feb 24, 2005 | 10:23 PM
hawkrod's Avatar
hawkrod
Welcome to our group. As a new member I am sure you will find a lot of neat stuff but I suggest that you probably should not respond to such old posts. there is no useful reason to respond to threads that went to bed almost a year ago. As far as the F25 vs F26 goes, that only tells you if it is a 2 wheel drive or a 4X4. a 78 that has a serial number begining with F26 is not a Hi-Boy, it is a Low-Boy. Hawkrod
Old Feb 24, 2005 | 11:00 PM
Mil1ion's Avatar
Mil1ion
76highboy4x4
Highboy
Please read post #8 on this thread.
https://www.ford-trucks.com/forums/s...d.php?t=102632
Some forums on FTE have READ FIRST: threads.
We would like every user who visits these forums to PLEASE read these threads.
That's why we post them in Red ,they are important
Old Mar 10, 2006 | 05:56 PM
1967Ford300's Avatar
1967Ford300
the highboys had 2 1/2 inch leaf springs, while the regular trucks had 3"
Old Mar 10, 2006 | 11:18 PM
Kahuna's Avatar
Kahuna
There is no regular truck,all 4x4 f250`s till 77 1/2 are highboys.There was no Highboy option and the term Highboy was not even given to them untill well after the design change.
Old Mar 10, 2006 | 11:41 PM
Craigwell's Avatar
Craigwell
Well I certainly don't mean to split hairs on it, but the term highboy was around from the very beginning.
After WW2, when interest grew in having four wheel drive on a big 3 truck, the big 3 responded.
They originally subbed out the work to convert the trucks to 4 wheel drive, and they ALL had a 'divorced' transfer case setup, and had to have some lift in order to provide clearance for the driveshafts and tcase.
The term 'highboy' was coined then.. suddenely in the 50's, you see, these trucks were running the roads a lot taller than their 2 wheel drive versions.
I *don't think* however, that the big 3 ever used this term themselves to market the trucks. (??) I know Ford didn't in the seventies, at least..
I DO agree that people shouldn't expect anyone at the Ford Dealer or at a parts store to necessarily know what a 'highboy' is.
Did this make anything any clearer?? ahahahahahahaha
Old Mar 10, 2006 | 11:54 PM
Craigwell's Avatar
Craigwell
I can tell you that it this point, my highboy has been reassembled, and I crossed Canada with it 1 year ago March 11th.
I now have a problem with the earlier mentioned power assist steering.. anyone have experience rebuilding the pitman-arm mounted valve? mine is now leaking, and seems to only divert fluid pressure to extending the piston, (right turns) and not retracting it. odd stuff.
and no, i wont be converting it to power steering... I happen to prefer the feel and response of the power assist, and dont have any problems with the rest of it.. high pressure hoses, rebuilt cylinder, etc..
any advice is most appreciated!
Old Mar 11, 2006 | 12:07 AM
CowboyPenner's Avatar
CowboyPenner
I've always had a thing for this era of truck. My uncle had one when I was younger and sometimes I'd get to ride in the bed which was a lot of fun.
Old Mar 11, 2006 | 01:35 PM
Mil1ion's Avatar
Mil1ion
Actually Craig, The original Highboy term was given to a 32 Ford Roadster that was fenderless.
http://www.streetrodderweb.com/features/0508sr_hall/
Old Mar 11, 2006 | 03:01 PM
  #28
Craigwell's Avatar
Craigwell
Hey Mil1ion, good to see your still around here, I respect your knowledge of Ford-dom.. :-)
That was an interesting ride on that link, and indeed, I didn't realize the 'highboy' term applied to old roadsters as well...
My main point, was that the term isn't a recent one.. certainly not looking to mislead anyone!
I cannot find the source of the info that indicated to me the term 'highboy' was used informally to describe early 4x4's.. I had read it somewhere online, and cannot find the article again.
All of this has me thinking a 'Historical' facts and info forum would be a nice addition to the site here..
But then again, I study history and I'm a little biased :-)
Cheers,
Jason
Old Mar 11, 2006 | 03:13 PM
  #29
Mil1ion's Avatar
Mil1ion
Head to the GAD forum and a have a look at the Original highboy and other related info I'll be posting in a few minutes..
Old Mar 11, 2006 | 05:53 PM
  #30
Kahuna's Avatar
Kahuna
Reguarding hot rods the term "highboy" has nothing to do with being fenderless though many were.It means that the body sat up on top of the frame as oppossed to the channeled cars the the body was lowered down over the frame.Most fenderless rods of the day were highboys and that is where the confusion in terms comes in.
