1978 - 1996 Big Bronco
Diagnostic port
Old Dec 14, 2003 | 12:20 PM
ojmjr's Avatar
ojmjr
Diagnostic port
I appear to have a bad connection somewhere between the port and harness on my 87 Bronco that is messing up the works (won't run).
I was told both fuel pumps went out. Replaced them and they did not work.
I attempted to ground out the pump circuit on the port to power the pump and when I moved the head (before jumping the circuit) the pump kicked in as it should. Moving the harness would repeat the result. Now I can't get anything.
Long story short, does anybody know if that part of the harness can be changed without replacing the entire harness??
If so, any good source?
Thanks to all who may help.
Please send any ideas to:
omenard@sbcglobal.net
Regards,
Oliver
