solid flywheel or not soild ?
Old Dec 13, 2003 | 04:17 PM
iconly1's Avatar
iconly1
hey i have a 1993 f350 turbo desil (not power stroke)
and need to replace a fly wheel and want to know the pros and cons on a solid flywheel and a not solid flywheel
Old Dec 13, 2003 | 08:39 PM
carnuck's Avatar
carnuck
there is no solid/non-solid that I know of. Just 2 different thicknesses. (extra weight is for heavier loads)
Old Dec 14, 2003 | 05:20 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Does your truck have the dual mass flywheel on it now?
Old Dec 14, 2003 | 11:37 AM
carnuck's Avatar
carnuck
The parts one in Chilliwack does (if you mean me!)
Old Dec 14, 2003 | 01:52 PM
Dave Sponaugle
I think the dual mass flywheel was in Powerstrokes only. It has springs in the flywheel to help absorb the power jolt from all the torque of the powerstroke. Luk makes a solid flywheel clutch that replaces the dual mass flywheel which is very expensive and does not hold up very well if you are hauling and towing a lot. I can not remember which driveline bearing seems to take the brunt of the shock load, but that was why they had dual mass flywheels. Most people I have talked to had nothing good to say about them.
Old Dec 14, 2003 | 05:49 PM
redneckmechnic's Avatar
redneckmechnic
they also sued teh dual mass to queit the tranny and as far as i no they also used them on the 7.3 idi motor. when i put my 5 speed in my 6.9 idi i used the soldi flywheel and got a clucth from a dual mass and made it fit. it works great but its really noise when its idling. give it some throttle wether yar in gear or not and it quiets rite down.
Old Dec 14, 2003 | 11:55 PM
Spectramac's Avatar
Spectramac
All of the 7.3 sticks I have seen have the dampened flywheel. I guess they thought it would be stronger than the dampening ring in the clutch disc. Only problem is the clutch costs less than a new flywheel.
Old Dec 16, 2003 | 05:10 AM
nogo73's Avatar
nogo73
I just replaced mine 12 "dual mass flywheel $700 dollars ;high performance 12" kevlar clutch, throw out bearing alinemnt tool ,new flywheel bolts $344.39
Old Feb 22, 2004 | 11:28 AM
fellro86's Avatar
fellro86
I replaced a dual mass flywheel with a solid on a friend's 94 7.3 turbo, and it seemed to have more torque after doing so. We got a kit from LuK for around $400, with the pressure plate and disc. His father was real impressed with it, and he had been the one to drive it most.
Old Feb 23, 2004 | 02:35 AM
carnuck's Avatar
carnuck
The automatic flywheel had a HUGE extra weight on it in the '91 7.3 my buddy had me pull last summer. We replaced it with a lighter flywheel 7.3L (didn't want to worry about balance trouble)
Devore95
Feb 24, 2014 02:42 PM
FordOwnerJoey
Oct 5, 2013 07:34 PM
quality1const
16
May 23, 2008 09:24 PM
fordmudrunner2020
Apr 26, 2005 10:47 PM
Darryl
Aug 12, 2003 09:39 PM
