Modular V10 (6.8l)
Transmission cooler?
Old Dec 13, 2003 | 10:36 AM
rick88's Avatar
rick88
2003 F-250SC 4WD V-10. I can't see a tranny cooler other than the lines running into the radiator on this truck. My 1998 F-150 had an external tranny cooler in addition to the lines running through the radiator. The only external cooler I can see on the F-250 is the power steering cooler. Am I blind or nuts or both?
Old Dec 13, 2003 | 05:44 PM
daimon1054's Avatar
daimon1054
I was told by Banks that the F250 had more than enough cooling for the trans. I never looked to see how it was set up but I figure if an aftermarket company is passing on trying to make a buck it should be OK.
Old Dec 14, 2003 | 07:37 AM
2000BLK54's Avatar
2000BLK54
If you are worried about cooling get a transmission temp gauge and monitor the tranny for a while. If it gets over 200 degrees for any lenght of time while towing or heavy work then start considering an auxilliary cooler. Two types I was looking at is a static aluminum tube with large heat sinks that mounts inline to the radiator feed line. The other uses a stacked plate radiator and a 400 CFM fan.
Old Dec 14, 2003 | 08:20 AM
OGNOM's Avatar
OGNOM
It is sandwiched in between the radiator and air conditioning coil.
