Brake Problems!! Need Help Please!
Old Dec 13, 2003 | 02:49 AM
Ed2004's Avatar
Ed2004
Unhappy Brake Problems!! Need Help Please!
Brake problems: I have a 1993 Ford F350XLT Diesel 7.3 Intl, 1 ton dully crew cab. I have not been able to get a full brake pedal. Have bled the brakes correctly, replaced master cylinder three times, booster, and equalizer. The master cylinder when plugged, you get a full solid pedal, with NO bypass, but when lines are hooked up, you get a bypass, and the brakes slowly sink to the floor. I have had more than three shops look at this, and they are all dumb founded.
Any help please!!!!
Old Dec 13, 2003 | 09:07 AM
fonefiddy's Avatar
fonefiddy
This is a strange one.
I take it, there's no fluid leaking? Does the resivoir stay at the same level?
Is your ABS light on?
93' has RAB's and there's a control valve on the frame rail right under the drivers seat.
Old Dec 14, 2003 | 04:25 AM
Ed2004's Avatar
Ed2004
Yes, there is NO fluid leaking, and the ABS light does not stay on. I think it only comes on when the truck is first started. The Reservoir stays full. What is really strange is that if the truck is not running, the pedal is full and solid, but once you start the truck, the pedal drops slowly to the floor, bypassing the all pressure. I have even replaced the booster.
Old Dec 14, 2003 | 09:47 AM
dieselzen's Avatar
dieselzen
Ed2004,
Have the shops checked all the vacuum lines for leaks, and the vacuum pump for output? Here is a quote from the 1992 Ford tech CD (principles should be the same for your year model):
".....For example, after braking to a hard stop, the vacuum in a diesel booster may be significantly reduced. If the driver continues to apply the brakes at the stop, the vacuum will start to build again, and the pedal will sink as the increasing boost moves the diaphragm forward. This doesn't mean there is a leak or a malfunction in the system. Always inspect the vacuum supply on a diesel before suspecting other defects when the complaint is pedal drop."
Perhaps, because you have a vacuum leak in the system, once the engine is started, the vacuum pump is always attempting to catch up.
Hope this helps, R.A.
Old Dec 15, 2003 | 12:08 AM
Spectramac's Avatar
Spectramac
We've gone through this before at our shop. We went through two master cylinders and replaced the RABS valve on the frame. We finally decided there was nothing wrong with it. They have so much power on the pedal with the motor running, it was actually bypassing the anti-lock valve and leaking off pressure. We finally took it on a test drive and it felt completely normal. As long as you've got all the air out of it, there's not much else you can do.
Old Dec 15, 2003 | 08:08 PM
Ed2004's Avatar
Ed2004
So is the Vacuum pump the suspect?
Old Dec 15, 2003 | 11:11 PM
FSC's Avatar
FSC
I have found that replacing the RABS valve usually cures a falling pedal condition even if it does not trigger a light or code.
Old Dec 15, 2003 | 11:19 PM
dieselzen's Avatar
dieselzen
Ed2004,
You say you've gone over the hydraulic system through three shops and they've not found anything wrong with that aspect. Seems to me it's worth hooking a vacuum gauge up to the pump to see what kind of vacuum you're getting off it ( respective, of course to whatever elevation you happen to be at) and also to inspect the major(if not all) vac lines for splits, holes, bad connections.
I think that if you have a problem and you've checked the hydraulic system thoroughly and have not checked the vac system which directly influences it, it's worth looking into. R.A.
