1978 - 1996 Big Bronco
Front Brake Pads
Old Dec 12, 2003 | 10:40 PM
BudArnold's Avatar
BudArnold
Question Front Brake Pads
Just a quick couple of questions. I am looking at a set of HP brake pads for the bronc on www.broncograveyard.com and it says that they work great on cross-drilled rotors. Are cross-drilled rotors mandatory to use these pads? Did the 92-96 broncos come with cross-drilled rotors from the factory? What exactly are cross-drilled rotors? Thanks, hope to hear from you guys soon!
PS you guys really are awesome! I have never seen such a wealth of knowledge in one place before. Keep on truckin!!!
Old Dec 13, 2003 | 12:23 AM
screwy's Avatar
screwy
No you don’t need cross drilled rotors. No broncos came with them. Cross drilled rotors have holes drilled in them to keep them cooler. You can look at them at broncograveyard.
Old Dec 13, 2003 | 08:39 AM
ckirwan514's Avatar
ckirwan514
i use cross drilled drilled rotors they work better than stock and last longer and do not warp. i also use ceramic pads the combination works very well. looking to convert the rears to disk
