timing chain tension
Old Dec 12, 2003 | 07:54 PM
slantfin's Avatar
slantfin
Question timing chain tension
Ok. I know you guys dont want to read another post about 4.6/5.4 engine noise but too bad! Ive gotta do something to quiet down my 00 eddie at start-up. I know it could be piston slap and would warrant replacement of the motor(or live with it), but Id like to check the tension on the timing chain first as some of you have stated this was the cause of your noise. How difficult of a job is it to get the covers off and what do I look for once I get there? Ive torn into my share of pushrod engines but this will be my first mod. engine.
2000 eddie 5.4 w/ 71k miles
Old Dec 12, 2003 | 10:31 PM
LxMan1's Avatar
LxMan1
Hi and welcome to FTE .
I haven't had the covers off of my 5.4 (hopefully, I never will) but the chain tension is done by tensioners that work off of engine oil pressure. The oil pressure pushes the tensioners out to take up slack.
Jimmy
Old Dec 12, 2003 | 10:48 PM
slantfin's Avatar
slantfin
Interesting. Ive read posts that these tensioners wear out and cause excessive slack in the chain. Thus causing a 'slap' similar to the dreaded piston slap noise.
Old Dec 12, 2003 | 11:00 PM
LxMan1's Avatar
LxMan1
I have read of the oil feed holes getting clogged causing them not to keep the chain tight.
Jimmy
Old Dec 13, 2003 | 12:03 AM
fixer's Avatar
fixer
Re: timing chain tension
taking off and reinstalling the timing cover is not a difficult job as far as precision is concerned. For someone who has never touched a modular before it would likely be a day's worth of work.
there are less intrusive ways to check for engine noise though. you might try getting a stethoscope from a parts store and poke around the timing cover area.
Old Dec 17, 2003 | 03:22 AM
re-engineered's Avatar
re-engineered
Chances of your tensioners being loose is remote. Ford did a good job designing this system. As lxman 1 stated this system uses oil pressure to maintain tension on the timing chains. There has been instances of the wear portion of the guides being wore to the point that you get slack on the chains but I have only experianced that in very high mileage motors. The best way to check is with a mechanics stethoscope. Keep in mind that if you decide to pull the front cover off you will have to pull both valve covers also. This is a feat that will take so time and patience.
Tmbradshaw
2004 - 2008 F150
Jan 1, 2015 01:53 PM
UNTAMND
Modular V10 (6.8l)
Jun 20, 2014 07:48 PM
kbsupercrew
1997 - 2003 F150
Apr 6, 2012 04:20 PM
eddie2112
2004 - 2008 F150
Jun 28, 2011 10:21 PM
burninfordrubber
1997 - 2003 F150
Jan 26, 2007 08:18 PM
