I am currently doing a 460 swamp into a 88 f-250. I removed a 300 6 cyclinder. and would like to know if the tack will work for the 460 or is it switchable for the 460.
The tach will work with the 460. I found that out by just hooking up one a bunch of years back. It runs off of the coil/distributor signal. 4-12 cylinders all use the same signal.
it may work, but I doubt it would be right
its triggered by the coil primary
on a V8 the coil fires 4 times per crank revolution
on a six it fires 3 times per revolution
there may be a switch or something to convert it
The factory tachs have an extra terminal that is grounded thorugh the engine harness in a V8 application.
I'm not sure where this is found on an 87-up however.
If your keeping an ECM it will work. The tack is controlled by the ECM which is matched to the motor. The ECM will send the appropriate signal to the tach, not the coil.
thanks for the info, my ECM is gone, going carberated and the diagram i have shows the tach as a stand alone unit triggered by the coil not the ECM. Just not shur about accuratecy.
