1978 - 1996 Big Bronco
Transfer Case... Help!
Old Dec 12, 2003 | 06:44 PM
89BroncoResto's Avatar
89BroncoResto
I have the Mazda M5OD Trans and a BW 1356-27 T-Case (Tag # E8TA-EA), and I'm getting a horrible vibration and squeeking sound when driving . I have new spider gears, rear axle bearings, brakes and drums, and am now turning to the t-case. There is plenty of fluid in the rear and t-case, and neither is leaking. Can anyone help?
Also, I found 2 replacement t-cases. Are the 1356 and 1345 interchangable?
Thanks.
Old Dec 12, 2003 | 09:18 PM
justshootme84's Avatar
justshootme84
I would check the clutch-pressure plate and throwout bearing as well as the driveshaft u-joints first. The 13-45 will work, if you change the shift linkage and bracket.
timscott76
Aug 15, 2014 02:45 PM
tilopa
Dec 3, 2013 01:44 PM
landon460
Oct 2, 2009 08:57 AM
BlueOvalDrifter88
Nov 17, 2005 12:14 AM
86rustbucket
Mar 2, 2005 11:24 AM
