Aerostar Ford Aerostar
Heater Core IN!!!!!but,,,
Old Dec 12, 2003 | 12:49 PM
Hammerhead's Avatar
Hammerhead
I am sure some will be glad to hear I finally got the new heater core through the fire wall. Now another question before I fasten it in. The original came with a neopreen rubber band gasket around the outside of the core box. There is no way on earth the new one will go on with the original gasket. Can I omit that supid piece of rubber? Please say yes. Or can I pack it with some other form of insulation? Thanks again in advance to all who help and hope for a quick reply, I'm almost there. !
Old Dec 12, 2003 | 01:34 PM
agelder's Avatar
agelder
I don't have any experience RE:this, but if worse comes to worse, do you have some gasket maker on hand? That stuff comes in handy and may work if you cant find something better.
Old Dec 12, 2003 | 02:45 PM
aerocolorado's Avatar
aerocolorado
I did a replacement with an aftermarket core that was too small to keep the gasket on. It worked okay but would rattle around in the case on rough roads. I eventually wound up replacing it with a Ford core, but otherwise, the smaller core worked fine during the time it was in there.
