rear door - again
This time,however,the very last linkage rod that attaches to the mechanism for the doorpost itself has fallen off completely!
I can see no way whatsoever of getting the door open now.I found this out when I went to put the rear bench back in for the winter(makes for good ballast)I ended up having to take out the middle captain's chairs and wrestle the bench in through the side door.On a good day I'm 145lbs and somehow did it without help or a hernia.
Question is - Is there any way at all to pop open that rear door?
There is no way that I can see how to get at it and of course no inside release.
I guess when it comes down to it I can live with it stuck closed but with the seats out the aerostar can put some pickups to shame with their cargo(dump run) capacity.
I would like to get the thing working again but I am perilously close to grabbing the welder and sealing the deal.
The only other thing is to remove the trim panel and totally remove the liftgate latch release control assembly (4 bolts) so you can get to the latch to lift it. LOL
Ron
