hydraulic clutch problem...please help
Old Dec 12, 2003 | 01:30 AM
will-work -for-mud's Avatar
will-work -for-mud
i put a new clutch in a 94 F-150 with the 4.9 inline-6. the new 11-inch clutch went in fine. the only problem is that i cannot get the fluid from the master cylinder to the brand new slave cylinder i just put in along with the clutch. i checked to make sure the slave cylinder was the same as the old one and it was exactly. i have no idea what to check. need to know some info. thanx in advance.
-Landon
Old Dec 12, 2003 | 06:03 AM
RTM's Avatar
RTM
How does the fluid look in the master cylinder? If its black looking at all it will need to be changed. Thats the only thing I can think of other than some air in the line or a bad slave cylinder.
Old Dec 12, 2003 | 02:50 PM
thesaintoc's Avatar
thesaintoc
I think the plastic hose has a check valve in it between the Master and the slave. I proved this when I accidentally stepped on the clutch pedal after the line was removed from the trans slave cyl. I would remove the line again and re-insert.
It should gravity bleed, as I have used a vacuum pump, leg power and gravity bleeding and they all work.
Thank God it is not as dificult as the Ranger set up.
I made the special tool to remove the line. Did you buy the special tool or fabricate your own.
