No turn signals...HELP!!!
Old Dec 11, 2003 | 08:04 PM
DiGangi's Avatar
DiGangi
Angry No turn signals...HELP!!!
I have a 1998 Ranger XLT 2wd. Today I had new 4 new tires installed and also an inspection done on the truck. Now my turn signals dont work?? I checked the fuse on the left side of the dash and it is fine. What could be causing this problem?
Old Dec 11, 2003 | 08:11 PM
Dealford's Avatar
Dealford
It doesn't cost much to replace the flasher. Use a test light on the fuse first though because a bad ground can "melt" the fuse instead of "blowing" it. "Melted" isn't usually visable, so you look at it and say, "Yup, the fuse is good."
Old Dec 11, 2003 | 09:22 PM
DiGangi's Avatar
DiGangi
No, I did use a test light on the fuse and it is working. I just can figure it out. If it was the flasher wouldnt the lights just stay on??
Old Dec 12, 2003 | 12:08 PM
Ken00's Avatar
Ken00
I would start by checking for power on both sides of the fuse.
Old Dec 12, 2003 | 06:56 PM
87 XLT's Avatar
87 XLT
What about the emergency flashers, do they work?
