Check out JL Audio, they make a box the replaces the center seat and is covered by your factroy cloth. This assuming you have the 40/20/40 front bench. I put this in my 99 SC, couldnt beleave the sound it put out, and the best thing is noone knows its there.
I made a 4" rear seat lift which alows me to fit a box with to 10" front firing subs under the now lifted rear seat it definitely beats the factory system. I believe there is a company on the web that sells a rear seat lift LMI welding but I'm not sure of the name also subbox.net sells a box that will fit under the rear seat of the Superduty.
