I just bought one of those Westin Bull Bars for 2002 Ford F150 4X4. I was looking into buying some lights for the bull bar. It can hold 2 6" lights. I was looking into getting the KC Daylighters. What kind of lights do guys recommend? Im just looking for good lights but I don't want to spend a fortune on them, probably no more than $140 for a pair. Any help and suggestions would be appreciated. Thank you guys.
I have the KC Daylighters and they are very bright 150 watts bright.if i were you id get those i have 2 of them and love them.took me a few hours to hook them up.If your going to get the 2 day lighters in the box it comes with everything oyu need just about.the only thing extra i needed was more wiring cause mine are mounted to my roll bar.
I have the day lighters, work wonders just about everywhere (except in fog). Just don't use them when tailgating a cop
Blazer lighting makes a similar 6 inch light with a 100w output at about half the cost, but does not include the wiring needed and they only come individually. They are a little dimmer but much more cost effective ($60 for both lights, the switch, and the relay, as opposed to $100+ for the whole system) and use the same style mounts. Hella also has a set of decent 100w (or possibly 150w, I don't recall) 6" lights comprable to KCs.
well, depending on your budget, i would recomend a set of piaas. THey are truly high quality lights. If they are more for looks than use, just get some stainless off-road lights from pro comp or somehting. They arn't as good, but they look ok and still do the job.
