Sponsored by: Kumho
Changing bolt patterns
Old Dec 11, 2003 | 11:15 AM
KJKozak2's Avatar
KJKozak2
Ok, probably a dumb question, but I'll ask anyhow.
I got a set of 15x10 steel rims with 8 bolt holes. My truck has 5 on 5.5. I'd like to take them to a machine shop and have them (somehow) convert them to 5 on 5.5.
Has anyone ever done this? Can it be done? Should it be done or is it just a bad idea?
Thanks!
Kevin K.
Old Dec 11, 2003 | 10:11 PM
FordPerf300's Avatar
FordPerf300
1 Ton Axles swap! Don't waste the time drilling them out, if they can even be drilled for that pattern.
Old Dec 12, 2003 | 09:42 PM
CENTRALKYMAN's Avatar
CENTRALKYMAN
WILL-F350-I-BEAMS-BOLT-ONTO-A-86-F150?
Old Dec 12, 2003 | 10:20 PM
FordPerf300
F250 and 350 are leaf sprung, you'd have to convert the axle to use coils or convert your truck to leafspring to use them, and if you were going that route solid D60 would be a better choice.
Old Dec 13, 2003 | 08:00 AM
CENTRALKYMAN
I-THOUGHT-ALL,THE,2WD,F-150,250-AND,350,USED-FORDS-FAMOUS-I-BEAMS?
Old Dec 13, 2003 | 02:39 PM
FordPerf300
Not always, i'm not sure of the years, some used a monobeam axle.
