RPMs when towing.
Old Dec 11, 2003 | 10:44 AM
jjjrobley's Avatar
jjjrobley
RPMs when towing.
I have a f250 v10 with 3.73 rear, I am towing a 9100 pound travel trailer. What RPM can I run for long drives 300+ miles normal roads? I can't tow in overdrive the RPMs are to low, about 1900 at 65mph. It runs about 3200RPM at 70mph. Is that to high for long drives?
Old Dec 11, 2003 | 10:57 AM
jimandmandy's Avatar
jimandmandy
What is the peak torque rpm of that V-10? Under load you should be running close to that. 1900 is fine for a diesel or the old 4.9 I-6, but not for most gas V-8's. 3200 is not that high for modern OHC gas engines anyway. 55 is the speed limit when towing in California. Can you get away with towing at 70 in Minnesota?
Jim
Old Dec 11, 2003 | 11:18 AM
Buzz Cut's Avatar
Buzz Cut
Jim
Like anyone in CA tows at 55 on a freeway
Old Dec 11, 2003 | 12:08 PM
shorebird's Avatar
shorebird
Triton® 6.8L
SOHC V-10
Horsepower (SAE net @ rpm) 310 @ 4250 Torque (lb.-ft. @ rpm) 425 @ 3250
6.0L Power Stroke® Diesel*
Horsepower (SAE net @ rpm) 325 @ 3300 Torque (lb.-ft. @ rpm) 560 @ 2000
http://www.fordvehicles.com/Suvs/exc...ecperformance/
http://www.fordvehicles.com/Trucks/s...ecperformance/
It looks to me that you are right at the torque peak.
Old Dec 11, 2003 | 12:33 PM
jjjrobley's Avatar
jjjrobley
Thank you for the info. 3200 just seemed to high for me. The speed limit is 65 and 70 on the interstates. We will be going to CO then to Rapid city SD this summer. This will be are first long trip.
Old Dec 11, 2003 | 01:28 PM
AggiePSD's Avatar
AggiePSD
What kind of fuel mileage are you going to be getting running that kind of rpm with a 9100 load? Just curious.
Old Dec 11, 2003 | 01:32 PM
jjjrobley's Avatar
jjjrobley
This fall I was getting 7-9 MPG towing, 10-12 when not towing. That was before I added the mods this winter. Just installed the chip last night.
Old Dec 11, 2003 | 03:01 PM
AggiePSD's Avatar
AggiePSD
Ok, thanks.
okie2020
Dec 15, 2013 02:48 PM
akhunter02
May 15, 2012 03:35 PM
jswharton
13
Dec 23, 2010 07:00 AM
sglynx1
Feb 12, 2007 01:13 AM
Kerr
Apr 17, 2006 11:54 AM
