Replacement fog light connector?
Old Jun 17, 2026 | 02:03 PM
Hawkbox's Avatar
Hawkbox
As I fix up my brothers 2020 F150 I've discovered the drivers side fog light is missing and the end of the cable appears to have been ripped right off. It's currently pouring rain and I don't want to crawl under so I figured I would ask if anyone knows if it's involved to replace the end with an aftermarket one? I'm comfortable doing wiring but I am not sure if I can replace a second of harness or if I will have to reterminate the wires by hand. Anyone know off hand a simple method to get this working properly again?
Old Jun 18, 2026 | 11:03 AM
JKBrad's Avatar
JKBrad
You will need to replace the entire harness, or find the pigtail end that you can cut from a harness on a wrecked truck, so that you can wire it onto the damaged end on the truck you are working on. If it's on the foglight side, just replace the light itself.
e23barton
Sep 6, 2020 03:12 PM
ngng
6.7L Power Stroke Diesel
Jul 21, 2013 11:13 PM
sflem849
Aug 25, 2007 08:35 PM
X10
Mar 15, 2004 09:44 AM
