Acceleration Issues and Surging at Constant Speed
Old Jun 13, 2026 | 10:14 AM
USFishin's Avatar
USFishin
6th Gear
I have an issue with acceleration and surging that I've been trying to get to the bottom of. When accelerating from a stop at a constant pedal position the engine is just groaning and very slowly accelerating. If I continue at the constant pedal position the Relative Throttle Position in the Torque app keeps ramping up higher and higher, sometimes up to 40-60, then all of a sudden the truck will kick in and start moving normally and the RTP will drop off instantly back down to the 10 range and the truck runs normally. I can get around this issue by pressing harder on the pedal. Also, while going a constant speed, whether it's slow like in a parking lot or on the highway with cruise control on, the engine very slightly surges up and down. I can notice it while driving because I can feel it, but I doubt it's enough for a passenger to notice if they're not really feeling for it. While it's doing this, the RTP is bouncing around slightly too with the pattern of the surging.
So far I've changed all the plugs and and coils (I did have some misfires, which are all cleared up now).
Changed out the TPS.
Cleaned the throttle body and MAF sensor.
Changed the fuel filter.
Changed the Purge Valve Solenoid (it was hissing some).
Checked around for vacuum leaks with a propane tank and hose (I think my vacuum is fine, it has a steady reading in Torque).
I've ordered a FPDM to swap out my original one. Not sure this is problematic though.
No CEL.
Any ideas on where to look next?
Old Jun 14, 2026 | 06:53 AM
techrep's Avatar
techrep
what motor your working on ? if you changed the TPS, I assume it's not a 5.4 3V.
Old Jun 14, 2026 | 08:58 AM
USFishin's Avatar
USFishin
6th Gear
It is the 5.4 3V.
This is what I changed: Motorcraft DY-1116 6L2Z-9B989-C Throttle Position Sensor
Old Yesterday | 04:34 AM
techrep's Avatar
techrep
did you remove and clean the throttle body ?
Old Yesterday | 07:26 AM
runthatjunk's Avatar
runthatjunk
Unplug one of the vct solenoids and see if it goes away. It sounds like what it does when the cams move for the EGR function
Old Yesterday | 10:42 AM
USFishin's Avatar
USFishin
6th Gear
Yes, it was actually pretty clean. l cleaned the MAF at that time too.
Old Yesterday | 10:43 AM
USFishin's Avatar
USFishin
6th Gear
I'm out of town right now but will try that when I get back in a few days. Assuming it goes away with a VCT unplugged, what would be the next step?
OBSession05
Jun 14, 2024 09:19 AM
gkm007
Modular V8 (4.6L, 5.4L)
Apr 5, 2017 08:48 AM
Idiomaticman
Jun 17, 2012 10:36 AM
vinman46
Sep 20, 2004 06:39 AM
