A few things chevys got right
Gave me the poorest excuse for a rental car ever.
--doors smaller than a hobbit
-rear view mirror blocks 100% of vision in any right hand turn. But.....gives an awesom excuse to run over bicyclists and pedestrians, should you get caught (in minecraft).
-infotainment system doesnt dim, and is about twice as bright as the cars headlights
- causes suicidal thoughts
Seeing how many K2XX are all ready rusted through the lower door skins and rocker panels here in western New York I just have no interest in owning another steel body truck again. In 7-8 years your rocker panels are shot if they are made of galvanized steel here, the aluminum will still be like new.
His last 2016 Super Duty Lariat White Tri Coat Metallic truck was rusting through everywhere. Door skins, rear wheel wells, rockers. The truck was eaten alive in the span of 8 years by the salt. First bubbles appeared on the rear wheel wells when it was only 5 years old. Steel just doesn’t work well long with northeast salt.
2 cents,
Dave
Just a quick note, the reduction in steel thickness was also accompanied by a change to high strength and advanced high strength steel materials in the panels. This allowed the "strength" of the panel to be the same but with a thinner material, which would also be less weight. What it doesn't help with though is corrosion, it will rust through faster.
Got to drive an L8T gas 2500 yesterday, man that thing was pretty disappointing. Feels like it has no ***** until almost 3,000 RPM where the 7.3 Godzilla pulls just fine from idle on. Once the 6.6 revs up it felt ok, but a lot more pedal input to get the level of pull I’m used to from my 7.3.
I don't think the GM 6.6L gas has the power the Ford 7.3L does, but one factor is the only rear axle ratio GM offers on the L8T is 3.73. A lot of 7.3L's have a 4.30 rear axle. The L8T has been very reliable though and once again GM created a really great platform for aftermarket 'crate' engines. The L8T's iron block is very heavy and has thick cylinder walls, it's very close to the LSX block except it's missing the extra head bolt bosses.
GM's is rumored to be working on a new HD gasoline engine. I am sure Ford is up to something too, I was hearing the 7.3L would get direct injection at some point.
I wouldn't be surprised if they switch to direct injection. Port injection on the 7.3 was a selling point for me.
Dual injection, was the rumor. Direct injection doesnt have the chops to be a work truck engine yet.
TPI, and direct, with indirect ignition (yay $120 spark plugs). Basically, new heads for the 7.3l.
They did put the dimple in the head in case, but I’m not sure they need or want to do it right now. The whole point of landing at the 7.3 displacement was reliable stoichiometric combustion with no spark retard even under heavy loads. Take the 5.0, EcoBoost, 6.6 L8T and they are all running non-ideal combustion with spark retard under load and in high heat. The 7.3 can keep the most efficient combustion in every cylinder literally in any situation and landed at its torque per cubic inch value for that reason. I supposed you could up her to 11:1 and add DI to increase power, but now you may be in a spark retard situation depending on load and heat. DI helps with detonation, but doesn’t exactly solve it without ignition timing help still.
There was a good interview with the chief engineer on YouTube where he explained the 7.3 can maintain its full 430 horsepower rating in any given situation where the EcoBoost and smaller V8 have to de-rate to avoid detonation.
Higher compression with a cam phaser that can retard all the way down to miller cycle, in combination with knock sensors and spark retard could be handy........with an oem supercharger.
But expensive. And the last thing ford needs, is more complexity.
This is what we're doing at NG powerplants with piston engine generators. With massive turbos, not superchargers.
For a constant output engine a turbo makes more sense than a supercharger, as you have nowhere near the parasitic loss. For an automobile, a turbo makes more sense from an economy standpoint for the same reason, but a positive displacement supercharger will give more consistent, and instantaneous, power. That said, variable vane turbos go a long way to solving the lag problem, especially if paired sequnetially with an even larger one. But now you are talking extreme complexity compared to a supercharger.
