90 Ranger engine replacement
Old Dec 10, 2003 | 09:51 PM
ranger_n_tn's Avatar
ranger_n_tn
Hello.
I have a 90 Ranger 2WD 5 speed, 2.3L. I (desparately) need to replace or rebuild the engine. I have come across a 97 engine sitting on an engine stand that does not appear to ever have been run. I believe it to be a factory engine, just never installed. I would appreciate any advice on using this engine - will the motor mounts fit, will it bolt up to the bell housing, etc. I believe they made a change to the block in 98.
Thank you in advance for any suggestions or advice. Please excuse any breech of etiquette in my part.
Old Dec 11, 2003 | 10:51 AM
Ken00's Avatar
Ken00
Welcome to FTE!!!
I'm not sure when they switched to the 2.5 but I'm sure someone can help.
Old Dec 13, 2003 | 02:18 AM
AlfredB1979's Avatar
AlfredB1979
You can get away with an engine as late as the 94 model year.
The blocks were tweaked a bit in 95 and some stuff got moved around when 95 came around.
