Sponsored by: Real Truck
View Poll Results: What would cause the issues
Alternator
0%
Battery
0%
Voters: 0. You may not vote on this poll
Electrical issues with 2 trucks
Old May 15, 2026 | 07:11 PM
kman222's Avatar
kman222
2nd Gear
The first truck has a problem with the battery light flickering cant figure out whats causing it to flicker
what we have explored already with it and done to find the issue is both alternators tested at orally's, added extra ground to alternators and brand new batteries. The truck does have a dual alternator system on it
The second truck is draining the main battery but not the secondary but will run off of the main when removing the secondary. We are trying to figure out if this is the alternator or the battery.
Thank you in advance.
Old May 15, 2026 | 07:57 PM
cski's Avatar
cski
Problem one might be the alternator belt slipping.
Old May 15, 2026 | 09:21 PM
Pikachu's Avatar
Pikachu
What are the trucks? Year, model, engine . .
Old May 15, 2026 | 10:03 PM
kman222's Avatar
kman222
2nd Gear
Year
The first one is a 2001 350 7.3 powerstroke and the secone is a 2000 250 7.3 powerstroke
Old May 16, 2026 | 06:22 AM
apache84's Avatar
apache84
I have a friend with a 01 250,4x4 ,73. He had a issue with the alt light staying on or intermittent a couple years ago??? The fix was a chafed or broken wire in the dash that runs from pass side to the cluster or something like that. Best I recall he had to basically have the dash removed to access it. I'll get a hold of him and get better details of things later today.
Old May 18, 2026 | 06:14 AM
apache84's Avatar
apache84
I heard back from my buddy. It turned out to the the alternator exciter wire. A mouse had chewed through the wire loop next to the passenger battery. Best of my recollection it was not easily visible and took a shop some time and tests to track it down.
Vijay
Sep 10, 2014 11:13 AM
Fishin76
Oct 18, 2010 09:53 AM
tbenks
Jan 25, 2010 06:15 PM
georgiaford67
Dec 3, 2007 10:57 AM
john1
Aug 22, 2006 12:46 PM
