Power-Deployable Running Boards
Old May 14, 2026 | 03:53 PM
SteveKoz's Avatar
SteveKoz
I'm in the process of building a 2027 Lariat with premium package. Also adding the chrome package. Then I see the option for these Power-deployable running boards. I got mixed feelings. I like the way the truck looks with them tucked away BUT just yesterday I saw an F150 with driver side down and passenger side up. I've read about how you just have to keep them clean and lubed... but this F150 looked pretty clean. Am I just looking for trouble? Local dealers didn't have any trucks with the chrome package so haven't seen the 6" Angular Bright Anodized step bars that come with the Chrome package. Thoughts? My brother got a 2024 Platinum and he really likes the power-deployable. Says they come down lower than his fixed 2017 F250 boards. IDK.. Leaning towards the 6" Angular Bright Anodized but thought to kick it around here first. Thanks
Old May 14, 2026 | 04:32 PM
kryichek's Avatar
kryichek
4wd Low
I have power deployeable running boards on my F350 and Expedition. They do come down further than standard tubes, etc. Every 2nd or 3rd oil change I spray some grease around the motors moving parts and havent had any issues.
Old May 14, 2026 | 06:18 PM
srkr's Avatar
srkr
Add AMP power steps aftermarket. Love mine.
You can changed the LED’s to any color under the sun, also you can choose different colors on deployed and extended.
Old May 14, 2026 | 06:55 PM
SteveKoz's Avatar
SteveKoz
I watched a video on installing them. Looked real easy. The only part I didn’t like was wiring it to the Trucks OBD2 port.
Old May 14, 2026 | 07:34 PM
StockHeightIsBest's Avatar
StockHeightIsBest
First time with them. I'm not sure yet how I feel about them. They are cleaner looking, and undoubtedly improve fuel economy a smidgen. I also feel like it's probably a REALLY REALLY good idea to put splash guards/mud-flaps up front if you have them...to keep gunk away from the mechanicals.
Old May 14, 2026 | 10:42 PM
jared.gourlie's Avatar
jared.gourlie
I’ve got the chrome package and power boards on my ‘23 lariat in antimatter blue. No issues yet. I like how they looked tucked up. Not sure if they changed on newer models, but the chrome strip on the edge of the boards isn’t that noticeable compared to chrome everywhere else. And they do come down lower than fixed boards, I’m 5’6” so it’s handy. I also added the the weather tech mud flaps to keep as much debris off the mechanisms.
The only thing I don’t like about them is that both sides deploy regardless of which door gets opened. I think it wa prior to ‘23 models, they only deployed on the open door side
Old May 15, 2026 | 05:16 AM
StockHeightIsBest
Chrome strip on the boards is one thing I'd love to get rid of. Would look better black or paint matched.
Old May 15, 2026 | 05:32 AM
saratoga2011's Avatar
saratoga2011
Get them.
Put the ford molded splash guards on the front to keep the spray to a minimum and they aren’t hard to keep clean. I pressure wash mine fairly regularly and keep the hinges and motors covered with fluid film.
Old May 15, 2026 | 05:37 AM
Ford6.7ski's Avatar
Ford6.7ski
Trailering
I have the brand new 2026 truck for about 6 weeks.
I found if I wanted certain options, they only came with the power running boards. AFIK, if you want certain options, no way around getting the retracting running boards.
I can adjust it so they don’t go up and down when I approach, only when I open the doors, but I can’t keep
it in the always down position. There was an option for stay down, but that’s only until you drive again.
My only complaint is the running boards do open with some force and I hope not on a tight area.
Old May 15, 2026 | 06:18 AM
FordExpy486's Avatar
FordExpy486
What part of the country are you in? If northeast absolutely positively do not get them.
If not in the northeast buy them and enjoy. Thick ice is their nemesis, besides that they seem to last fine down south. Up here the last thing I want is to babysit those stupid running boards.
Here in Buffalo you even have to disable your auto fold mirrors in winter I’ve learned. They will ice over so hard the motors will struggle and then give up trying to fold open. I keep them off after November
Old May 15, 2026 | 06:23 AM
srkr's Avatar
srkr
It’s plug in, minus one easy wire. Pretty simple. The whole install, by myself took 7 hours. That’s removing the old ones as well. I would do it again.
Old May 15, 2026 | 06:37 AM
SteveKoz's Avatar
SteveKoz
Here in Buffalo you even have to disable your auto fold mirrors in winter. They will ice over so hard the motors will struggle and then give up trying to fold.
I live in the north east. Was thinking about those 1/4" ice storm that covers the truck but since they are tucked under the truck they wouldn't get a coating so "should" open? How about snow on boots? I stand on my boards now and kick off as much snow as I can before getting in. Snow will sit on the running boards. Will that be enough to stop the boards from staying retracted? Nothing takes away from a nice truck like seeing one board down while heading down the highway...AND you don't even know it's down. Thought about adding a button plunger and some lights in the cab to let me know if the landing gear has fully retracted... :-)
Old May 15, 2026 | 06:41 AM
srkr's Avatar
srkr
On the amp steps there is an app on your phone that tells you when your steps are deployed, also while driving you can deploy and retract through the app. If it’s your thing it also tells you the force applied opening and closing. I just set mine and forget mine, Now when I go hunting and it’s muddy I drive through a car wash and manually deploy them to get the mud off of them.
Old May 15, 2026 | 06:48 AM
SteveKoz's Avatar
SteveKoz
Wiring in general never bothered me. I just installed tankless air horns which was fun. I can understand it plug's into the board motors on both sides. What's it plug into on the truck? You'll need power supply plus wires to know when the doors have been opened and closed. Video showed one wire to the battery and two to the OBD2 but said you'll need to figure out which 2 wires on your truck since it may be different. I'm running into problems with the new ARE Z series cap. My current cap lock operates with the truck locks. Dealer just told me they can't use the truck locks anymore because the extra draw of power to trigger the cap lock causes a code fault with the truck computer. Also said the wires have become so thin that splicing into them is difficult. Manufacturers haven't added a plug in port for this feature. Did they add a plug in port for power running boards just in case someone added them during their build?
Old May 15, 2026 | 07:59 AM
FordExpy486
The issue is snow still finds its way in them with them retracted and it starts building up anyway. You also get the ice dams from the snow throw off the front tires that builds up toward the front open or closed. My family have had quite a few Denali Yukons, those boards never make it past year 2 of ownership…usually they fail in the downward position on one side and you have a lopsided truck lol.
Johnny F2 fiddy
May 15, 2026 07:26 AM
Xwild
Jul 19, 2022 06:30 PM
54LFL
Jul 12, 2017 02:02 PM
Blk04Snake
Sep 6, 2016 10:43 AM
