Glove box lock assembly
Old Dec 10, 2003 | 08:33 PM
skeneguy's Avatar
skeneguy
I bought an 82 F150 with the glove box door removed. I have the door, but there is no lock mechanism attached, just a square hole. I planned to get a lock from the dealer, but don’t know if I’m missing anything at the glove box. Can someone tell me if there should be a strike plate or a lock catch of some description or does the lock on the door secure to the underside of the dash when the door closes??
Thanks SG
Old Dec 11, 2003 | 02:55 PM
locknkey's Avatar
locknkey
Why not get a cheap lock from a junk yard donor Truck and then have it keyed to your door key .....locksmiths can key yours to the key you have.
Old Dec 11, 2003 | 02:56 PM
Txquadhunter24's Avatar
Txquadhunter24
the glove Box has a catch at the Top center which holds the door closed and the Lock is found inside latches center. To get a better Idea try going to a wrecking yard near you with 80-86yr models and get the pieces much cheaper and you'll know what you might be missing
Txquadhunter24
Old Dec 12, 2003 | 08:41 AM
hangman's Avatar
hangman
glove box
mine was missing also,took it out of 79 fairmont,later replaced fairmont lock and latch with one from 87 mustang!very generic!!
Old Dec 12, 2003 | 09:35 AM
skeneguy's Avatar
skeneguy
Thanks, that's good too know some vehicles are interchangeable, not too many wreckers close by me.
Old Dec 12, 2003 | 06:00 PM
GypsyR's Avatar
GypsyR
There are also a bunch of "non-locking" ones to be found in the junkyards. A locking glove box was an option. Either latch assembly will work just fine and they install identically.
There should be a "catch" on the dash itself, held on by two screws, at the top center of the glovebox opening.
ridealong34
Jan 27, 2014 11:01 AM
Nojive55
Jan 16, 2014 09:32 AM
cts1954
May 5, 2008 01:11 PM
350z
Jul 10, 2005 06:57 AM
stevehillesland
Feb 21, 2001 11:59 AM
