Steering Gear
Old May 13, 2026 | 08:33 PM
DDDDDMorgan's Avatar
DDDDDMorgan
Steering Gear
Well it's been forever since I've logged in and since I now have to drive my 89 F150 2WD every day to commute to work I'll be back looking for insight ;-)
To make a long story short I was trying to improve my steering and I messed with the adjustment screw on top of the steering gear. I know...
Anyway, now it's a bit "wonky". The truck was in bad need of rebuilding the front end but it drove straight down the road it just had that really mushy feel the trucks are well known for. I now know I should have started with the rag joint and then worked on front end parts.
I'll try and describe how it drives now, it used to float now it feels like I feel every rut in the highway and the steering doesn't work and then it grabs.
I've honestly lost track of where the adjustment screw started so should I loosen or tighten it?
I know I'm a dummy, lesson learned.
Old May 14, 2026 | 12:32 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by DDDDDMorgan
… that really mushy feel the trucks are well known for.
They are? That’s news to me.
By over tightening the screw it sounds like you have damaged the gear.
Old May 30, 2026 | 04:55 PM
Doug099's Avatar
Doug099
Are you still having problems with your steering?
I'll go into a little explanation how to adjust the steering box.
First you've got to make sure the steering box is dead center. The easiest way is to start the truck turn the steering wheel lock to lock counting the turns. If there's 3.5 turns then go all the way in one direction and bring the steering wheel back 1.75 turns.
Now the steering box is in the center. Loosen the jam nut for the pitman shaft keeping a wrench on the jam nut and using a screwdriver or allen wrench turn the threaded adjustment bolt in until it bottoms out don't over tighten it. Then turn it back out 1/4 to 1/2 turn and lock the jam nut while holding the adjustment bolt from turning.
The reason for making sure the steering box is in the center, is because the pitman shaft gear's middle tooth is a bit longer than the 2 side teeth. This helps keep a little tension on the over center movement of the steering box when driving straight down the road.
Hope this helps.
Old May 30, 2026 | 07:53 PM
My4Fordtrucks
Now explain what happens if you overtighten the preload adjustment screw.
Old Jun 4, 2026 | 10:49 AM
Doug099's Avatar
Doug099
Depending on how tight you over tighten it, you could experience the steering wheel not returning to center when you let go after making a turn, stiffness or binding in the steering wheel getting stiffer as you pass over center to all out locking up the steering box. The gears in the steering box are cut on a slight taper so the further you tighten the adjustment screw the tighter they wedge together.
Now if it's too loose, you'll experience slop the steering wheel and possibly constantly correcting. This will also be amplified if there are worn parts or the alignment is off. If the rag joint is worn, no amount of adjustment will take out the slop and you'll probably hear and feel a clunk while driving.
Bronccat
Jul 25, 2025 09:07 AM
jgavac
Jun 14, 2017 05:24 PM
Onebigtoy
Nov 30, 2016 01:04 PM
Fordication
Jul 19, 2016 10:19 PM
LRWC
13
Oct 4, 2012 07:20 AM
