Weird codes - PCM failure?
Old May 12, 2026 | 12:48 PM
snowdog79's Avatar
snowdog79
2010 5.4 displaying the following codes:
P0113 air intake sensor
P0453 evap sys pressure sensor
P0533 Refrigerant pressure sensor - High
The MAF has been replaced with no change
The A/C pressure sensor has been replaced with no change
P0453 comes up as the fuel tank pressure sensor reading high, but there is no pressure in the tank
long story short - my wiring harness back by the fuel tank near the pump got chewed in half by my dog. Every wire all the way through. I repaired the damage, but these all appeared after a got it to start. No codes previously. Runs great but the cooling fan is always on, no A/C.
My first thought is that the PCM was damaged as there had to have been shorts where the wires were chewed through. Thoughts? Can I replace the PCM with a used one myself, or does it need to be coded to the truck?
Thanks for any input!
Old May 13, 2026 | 07:27 PM
HomerWinzlow's Avatar
HomerWinzlow
Double check the Yellow and Violet wire from those sensors to the PCM pin 58 on Connector 175B. That is the signal return wire for the Mass Air Flow Temperature Sensor, AC pressure transducer, and Fuel Tank Pressure Sensor
Old May 14, 2026 | 10:47 AM
snowdog79's Avatar
snowdog79
Thanks! I will look for a schematic so I can identify the pins. This makes a lot of sense.
Old May 14, 2026 | 11:45 AM
snowdog79's Avatar
snowdog79
Initial testing indicates an open circuit as testing from the MAF to pin 58 is not showing continuity.
Old May 14, 2026 | 11:47 AM
HomerWinzlow
Well now you know what you are looking for.
Old May 14, 2026 | 11:44 PM
2009fx45.4's Avatar
2009fx45.4
1st Gear
Having exact same problem Right now what was dix or any leads
Red04six0
Oct 27, 2024 09:09 PM
yellowfever
Jul 20, 2019 03:22 PM
Jacab Gibson
2004 - 2008 F150
Dec 9, 2016 07:24 AM
tattooed_yoshi
Nov 17, 2013 09:33 PM
Donny_D
Jan 10, 2008 07:46 PM
