Oil change
Old May 10, 2026 | 08:40 PM
blakek04's Avatar
blakek04
1st Gear
Oil change
Wondering if this is normal. Can’t usually see a filter on my lower cars so I’m unsure if the gasket is normally seen.
Is the gasket being seen normal? Can’t normally see the filter on my cars. And this is the first change I’ve done on my truck.
Old May 10, 2026 | 08:54 PM
cpobst's Avatar
cpobst
It almost looks like the old gasket stayed on there based on the spacing between the filter and the housing.
Old May 10, 2026 | 11:19 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Gas engine with that sandwich oil cooler on the side of the block.
I'd say it is probably normal, but you could pull it back off to check and make sure the old gasket didn't stay on when you put the new filter on.
Old May 11, 2026 | 08:07 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
If it doesn't spew oil everywhere when you start it up, it's good.
If it does, the old gasket stuck to the housing and you'll have to remove it.
Old May 11, 2026 | 08:18 AM
Sedonut's Avatar
Sedonut
It's probably good, it you have a double gasket it will blow out oil really quickly. And I don't mean drip, it will be like you pulled the drain plug.
meat9
Jan 17, 2024 09:28 PM
Ltngdrvr
Nov 8, 2023 05:17 AM
bassdr
Oct 1, 2023 01:17 PM
Jointasset
Oct 18, 2019 07:43 AM
acl9865
22
May 26, 2018 08:44 PM
