460 heads
Old Dec 10, 2003 | 07:25 PM
hotrod ranger's Avatar
hotrod ranger
460 heads
I am gonna sink a 460 in a ranger and i wanted to know about the stock heads on the 460. Can anyone tell me if any of the heads have screw in studs and how big a cam i could run on a set of stock heads without getting spring bind.
thanks donnie
Old Dec 10, 2003 | 09:34 PM
fordman428's Avatar
fordman428
post it in the 460 forumn, you will get a lot more replys. you can put in studs i dont know if they came with them, and im not sure how big of a cam you can out in a 460 with out changeing springs etc.. but i bet the guys in the 460 forumn can help you out.
Old Dec 11, 2003 | 11:17 AM
georgedavila's Avatar
georgedavila
'68-71 heads have screw-in studs. .522 is about maximum lift on stock rail rockers before spring bind.
Old Dec 11, 2003 | 07:49 PM
hotrod ranger
thanks for the info i wil try posting in the 460 forum also
donnie
Old Dec 12, 2003 | 02:53 PM
airharley's Avatar
airharley
I am running a set of D3VE's with 7/16's studs and a .580 lift. I had to have the stud pads and spring pockets machined though. I did some serious machine work to mine to improve the performance on them. I also needed the larger chamber volume to keep it on pump gas. 68-71 heads have a 72-76cc chambers while the later heads have 92cc's.
Old Dec 13, 2003 | 04:43 PM
hotrod ranger
I have a set of DIVE heads and a set of D3VE heads. Which would be the best for racing and how much horsepower can i get out of them
Thanks Donnie
Old Dec 13, 2003 | 06:45 PM
georgedavila
Hi Mark, how's the new engine running?
Old Dec 13, 2003 | 06:51 PM
There Goes The Neighborhood's Avatar
hotrod ranger,
The D1VE's are three times the heads that the D3's are. Use them, and a good set of springs, and you can run any cam you want. Get a 3 angle valve job, a little port work, especially on the exhaust side, and the sky's the limit as far as the power's concerned. Also, when having them worked over, have the 2.19 intake valves installed, and use the 2.25's only for use above 7500 rpm.
Old Dec 13, 2003 | 08:15 PM
airharley's Avatar
airharley
georgedavila I can't complain about it. So far I have been able to max out the speedometer moving maybe 25 feet. Not bad for my old truck. Of course having a 4000 lbs truck helps that alot. Driving on the freeways out here in SoCal is a little different. Every time I am next to a Mercedies or BMW they give me a dirty look. But that is their problem not mine. I have to put my baby up for a year though, I have to ship out to Iraq next month. So in the mean time I am starting to buy all of the things I will need to make sure she's taken care of while I am gone.
Old Dec 14, 2003 | 08:39 AM
georgedavila
That's because they're eating big lease payments every month.
Good luck and be safe on your deployment.
