Free stuff
Old May 7, 2026 | 10:34 AM
speakerfritz's Avatar
speakerfritz
Free stuff
I’m clearing out my shed for more junk so up for grabs are a few things.
if no takers..re cycle back n bound
hopefully some one can use some , rather see it put to use than re cycled since I paid good money for this stuff.
don’t want a dime, just pay shipping.
ill update with a good box size so you can calculate shipping from 10305 to your zip. we can do UPS pickup aranged by you or USPS .
might take me a few days to round up a good box.
send me a pm and I’ll go thru those .
no technical support..get the parts and figure it out. Anything known will be included.
PMs only if interested.
will be listing more stuff and don’t wat to clog up the thread with interest interactions and how do you do this and that questions.
mill be adding to the list as I clear out my shed.
remminder....send me PMs if interested in anything ....I want to keep the list of free stuff tight so its easier for folks to go thru the list.
Old May 7, 2026 | 10:37 AM
speakerfritz
First item
pmf dual steering stabilizer brackets
minus bolts and u bolts
no shocks included
it will work on Dana 60 or Dana super 60 front axle setups due to the bolt pattern.
i removed this becuase I changed directions and went to a Stryker setup.
Old May 7, 2026 | 10:39 AM
speakerfritz
Dana 60 or super 60 front cover
might be handy if you do a lot of repairs and run into stripped plug holes. Or if you want to model one.
Old May 7, 2026 | 10:53 AM
speakerfritz
claimed
shipped may 11
Spe intercooler to intake pipe. Almost new
installed it and had it going for a few hundred minutes miles. I ran into a problem with the location of the npt ports vs the location of IAT sensor…I was spraying the sensor with methonal injection and confusing my pcm.
switched to pusher which has IAT away from npt ports.
I had it installed on a 2019 so 2017 thru 2019 will definitely fit. 11 thru 16 might not work unless you are good at stretching hoses…the intercooler side on 11 thru 16’s are different size than 17 rhru 19. Not impossible but it will be some work on 11 they 16’s. Maybe an adapter or something.
you need your own retaining Clip for the aluminum section, your own not plugs, your own clamps.
Old May 7, 2026 | 11:02 AM
speakerfritz
5” lift blocks
hole was drilled for DRW, if you want to use them on SRW you will need to put spacer bushings on your pins .
Old May 7, 2026 | 11:04 AM
speakerfritz
Track bar 3.5 drop bracket
Old May 7, 2026 | 11:41 AM
speakerfritz
Stock metal engine oil pan
Old May 7, 2026 | 11:44 AM
speakerfritz
Stock trans pan
Old May 7, 2026 | 11:50 AM
speakerfritz
Stock 2019 hot side intercooler pipe
Old May 7, 2026 | 12:06 PM
speakerfritz
claimed
shipped may 11
Stock cold side intercooler cooler
2017 thru 2019
about 10k miles on it when pulled off for a bling pipe.
would make a good spare
Old May 7, 2026 | 12:11 PM
speakerfritz
Old May 7, 2026 | 01:13 PM
Joe T's Avatar
Joe T
Shipping to 77007, plus boxing cost please.
Old May 7, 2026 | 03:13 PM
speakerfritz
claimed
shipped may 11
S&B map spacer
I think this fits 11 thru 19
bought a bunch of banks stuff which included a new map spacer
Old May 8, 2026 | 10:26 AM
speakerfritz
3.5” radius arm drop brackets
this is an extra set I never used
This will reclaim caster lost from level kits and lifts with out the need for bushings
Old May 11, 2026 | 08:54 AM
speakerfritz
spe cold side, stock cold side, and s&b map spacer claimed and shipped
I still have the brackets for PMF dual steering stabilizer for dana 60 and super 60 trucks as well as 3.5 track bar drop bracket, 3.5 radius arm drop bracket, 5" lift blocks and some stock pans.
